01-20-2010 07:47 AM - edited 03-14-2019 05:08 AM
In Cisco Supervisor Desktop User Guide and in the console help file, I read it is possible to configure, in the Supervisor Work Flows, some triggers and some actions to play if triggers are reached. This actions are :
But in fact, in my own supervisor desktop, the only action is Tree Control Action.
How is it possible to have the other actions available ? is it a licence problem (We are running on a Enhanced version).
thanks in advance for your help.
Philippe
Solved! Go to Solution.
01-21-2010 08:29 AM
You need premium license to activate those actions.
01-21-2010 08:29 AM
01-21-2010 08:38 AM
Thanks you for your answer.
Philippe
