01-03-2020 09:05 AM
Good Afternoon,
I did some searches on this but the only results I found were that Maximum Number of calls should be set to 2 and Busy Trigger set to 1.
We have a scenario where an agent occasionally has to place simultaneous calls to Tier 2 support as well as Foreign Translation Services, which makes 3 concurrent calls on the one line, exceeding the supported configuration.
Does anybody have a workaround for this?
I tried placing the maximum number of calls to 3 but that has caused issues with functionality/reporting
My only other idea would be to place a second DN on the phone, the only issue there that I can see is it sends the agent into work mode once the call is conferenced in on the second line-- not an end of the world but technically they aren't in work mode yet so they would have to change their state which I could also see some reporting issues resulting from it.
Thanks in advance,
Rick
01-03-2020 05:05 PM
Hey Rick,
I think that there is no easy way to workaround your requirement. Below you will find an idea of solution that might work for you, but it will require some development effort. I didn’t test this solution and I don’t guarantee it will work but, in my opinion, from high level it looks ok. In general, it should allow you to multiplex more than 2 expert calls having primary call on hold. I’m not sure how this will affect the reports, but the stats can look better compared to multiline implementation or not supported value of Max Calls. So, here is the idea:
Requirements
How it will work
To avoid any issues, all Expert calls that are active and use a session server need to have a heartbeat mechanism implemented on the gadget side.
01-08-2020 10:27 AM
Thanks Marek,
I will keep this in mind and maybe work on this in my spare time as a mini project. If I get it working I will post my results here.
01-04-2020 12:54 PM
+5 for Marek for proposed solution. But to keep things simple as you suggested simply add another personal line appearance on the phone for agents to use to make these outbound calls.
01-08-2020 10:52 AM
Thanks Chris,
I will most likely be implementing this for at least more logical reporting.
Just kind of a follow-up question: Is there a particular reason why the phone will hang up Line 1 when conferencing it into Line 2? I would think this is by design since Line 1's extension would essentially be inactive, I was just hoping to know why. I that in Finesse, the call from the desk phone shows 'XXXX.YYYY where XXXX' is line 1's extension and YYYY is line 2.
Any insight would be helpful, I would think this maybe due to the phone only capable of one RTP stream whereas kepping both lines active on the same call would create two separate streams. And then my other thought was that it would create hairpinning within the phone.
01-08-2020 03:53 PM
Right, you cannot conference 2 lines from the same phone with each other because only one stream can be active at a time. Why would you ever want to do this?
