BAPI not found with technicalName /v1/energy/trendAnalytics
tschleicher
im running CCC Version 2.3.7.9 with Version 1.19.87 for the API (AI Endpoint Analytics API Enabled), no update Availible.
for https://<ccc-ip>/dna/data/api/v1/energy/trendAnalytics
Im getting...
    "error": "BAPI not found with technicalName /v1/energy/trendAnalytics and restMethod POST"
and for basically any other energy related API Call.
I even read through Assurance/CE_Cat_Center_Org-deviceEnergy_1.0-1.0.1-resolved.yaml and tested the calls mentioned there.
But nothing works and API Calls are not found. Anyone facing similar issues ?
These API´s doesnt appear in the Catalyst Center Developer Toolkit either. Is there a way to manually update them ?
Torbjørn
I am getting the same result on my lab Cat-C. I would create a TAC case for this. There have been some inconsistencies in the Cat-C API in recent releases, it would not surprise me if something has changed and the docs just haven't been updated.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
