how do I get top 10 WAN interface utilization through a API
dtota
colo
Jon,
Great point - I was wrong in my prior response - the WAN status doesn't get you closer to the top 10 WAN links.
The best way to calculate network usage via API is to do a sum of all the clients on the MX.  Request the clients data from the API endpoint for /devices/[serial]/clients?timespan=XXX.
API Docs:
https://dashboard.meraki.com/api_docs#list-the-clients-of-a-device-up-to-a-maximum-of-a-month-ago
This statement requires the clients data from an MX100:
curl -X GET \
  'https://dashboard.meraki.com/api/v0/devices/Q2JN-RD78-XJNM/clients?timespan=100000' \
  -H 'cache-control: no-cache' \
  -H 'content-type: application/json' \
  -H 'postman-token: 156f0307-e4a3-fa76-4aff-654737a2ca9a' \
  -H 'x-cisco-meraki-api-key: fa1d2daa7bb8b71d5d87e1ee19ae55dacda0435d' \
  -d '{
    "enabled": false
This returns the client usage sent and received:
        "usage": {
            "sent": 10143.885104300918,
            "recv": 0
        "id": "k945d80",
        "description": "sf-mv-1-9-e0553d830582",
        "mdnsName": null,
        "dhcpHostname": "sf-mv-1-9-e0553d830582",
        "mac": "e0:55:3d:83:05:82",
        "ip": "172.16.1.16",
        "vlan": 1
Now just sum all the clients on the MX and you have the site's total usage. Do this for every site and you have your top 10.
Colin
7 Replies 7
I tried this in Postman and I just got empty array [] in the return. I tried this on the sandbox environment. Is this normal? Also, is there any documentation on the return JSON object?   Thanks
I think there's an issue with my Sandbox because the Dashboard doesn't show any data either.
colo
There is no issue with the sandbox it just doesn't have much traffic as it's not a production network with users on it. Try this on your own network, or try this API key with the "Meraki Live Demo" organization, so take it for a test drive:
For example, this statement:
curl -X GET \
  'https://dashboard.meraki.com/api/v0/networks/L_646829496481087790/traffic?timespan=10000' \
  -H 'postman-token: d320422f-7a43-da8a-0dfe-1b690ae93712' \
  -d '{
    "enabled": false
Returns several applications starting with pings:
        "application": "ICMP",
        "destination": "8.8.8.8",
        "protocol": "ICMP",
        "port": "-",
        "recv": 3771,
        "sent": 3772,
        "flows": 0,
        "activeTime": 45960,
        "numClients": 5
Hi Colin,  How does the uplink API provides information on network utilization? I dont' see any traffic related information in the return JSON.  Thanks
colo
Jon,
API Docs:
curl -X GET \
  -d '{
    "enabled": false
        "usage": {
            "recv": 0
        "id": "k945d80",
        "mdnsName": null,
        "vlan": 1
Colin
Colin,
I'm trying to do something similar however I would need to separate usage on the interface level when there are multiple
interfaces on the appliance. Looks like the data is there as it shown on the  Appliance Status --> Summary page and I would like to retrieve it with the API.
Imre
