取消
显示结果
搜索替代
您的意思是:
查看次数
6
有帮助
回复
More than one host obtained for hostip:X.X.X.X
Guangming_Li
Hi There,
With APIC-EM path trace, i keep getting error : More than one host obtained for hostip:X.X.X.X.
I am pretty sure there is no ip conflict in our environment,  Does anyone know where the error is from?.
the APIC-EM version is 1.2.0.1594
Cheers,
Guangming
3 条回复3
aradford
If you look in the host table, is there more than one entry for x.x.x.x?
Adam
Thank you for your help Adam.
I do see multiple entry for same ip address. Please check screenshot below and you can see APIC-EM shows 172.16.64.90 and 172.16.68.91 are connected to switch53 and swtich54, but it’s wrong. They are actually connected to another switch. I couldn’t understand how it happened.
Also the topology generated by APIC-EM is totally wrong. Some switches are on different site, but the topology shows they are connected directly. How can I fix those issue?
Cheers,
aradford
This is strange.
What version of controller are you running?
Are you running CDP on the switches.
Do you want to try deleting the switches and rediscovering them again?
