PKI not working after rebuilding HUB
ubsaccount
We had the hub sites deployed but  wanted to change some stuff but you can't after you create them
So we rebuilt it now we can't get the PKI to work anymore.
Does anyone have a solution for this?
5 Replies 5
ngoldwat
Level 4
Level 4
You say you rebuilt them as opposed to redeploying them?
Yes, we wiped out the configs rebuilt it and tried to redeploy them.
did you redeploy the spokes as well?
We don't have any spokes yet
that is strange.  Did you delete the hub from APIC before the reprovisioning?
Worst case, if you wanted to start again, you could just "reset_grapevine" and say "Y" to the destroy disk question.  That would reset your controller completely and you could redeploy fresh.  You should not need to do this?
Are you sure it is not a licensing issue?  Do you have the correct licences on the HUB devices when you rebuilt them?
