Robot genie variable handling
george_daly
Level 2
Level 2
Hi there, I'm having problems with the genie parser library in robot framework.  I'm basically copying the approach from the example in https://pubhub.devnetcloud.com/media/genie-docs/docs/userguide/robot/index.html
If I try this .robot file to parse the output of show version, store it in a variable, then query it with dq:
*** Settings ***
Library    unicon.robot.UniconRobot
Library    ats.robot.pyATSRobot
Library    genie.libs.robot.GenieRobot
*** Variables ***
${testbed}     testbed.yaml
*** Test Cases ***
Connect
    use genie testbed "${testbed}"
    connect to devices "leaf1"
parser show version
    ${output}=    parse "show version" on device "leaf1"
Verify version
    dq query    data=${output}  filters=contains('9.3(8)').get_values('system_version') on device "leaf1"
Disconnect from device
    disconnect from device "leaf1"
The parser passes, but the verify fails because the variable is not found:
parser show version                                                   | PASS |
Verify version                                                        | FAIL |
Variable '${version}' not found.
If I do the same thing directly in python it does what I expect, e.g:
from pyats.async_ import pcall
from genie.testbed import load
from genie.utils import Dq
from rich import print as rprint
def get_version(hostname, dev):
    parsed = dev.parse("show version")
    get_version = (Dq(parsed).contains('9.3(8)').get_values('system_version'))
    rprint(get_version)
testbed = load("leaf1.yaml")
testbed.connect(log_stdout=False)
results = pcall(get_version, hostname=testbed.devices.keys(), dev=testbed.devices.values())
Results in:
gdaly@pop-os:~/PycharmProjects/evpn/tests$ python3 verify_version.py
['9.3(8)']
Can anyone see where I'm going wrong here?
Alexander Stevenson
Hi @george_daly,
I'm not a Robot Genie expert but I found this:
"Variables can also be given from the command line which is useful if the tests need to be executed in different environments. For example this demo can be executed like:
robot --variable USERNAME:johndoe --variable PASSWORD:J0hnD0e QuickStart.rst
This could be useful in debugging, i.e. see if it passes with variable given through CLI.
Another thought, could you rename the 'data' variable as 'version'? Maybe that's what it's looking for.
Hope this helps!
