Terraform resource ACI BGP Peer connectivity using Interfaces
Adhiputra
Visitor
is there a resource to configure bgp peer connectivity using physical interfaces inside of l3out ?
I try using this resource code, but it creates bgp peer using loopback interface, seems there is no option to choose physical interface in this resource
resource "aci_bgp_peer_connectivity_profile" "SR-XXX_GLOBAL_L3OUT-L201_NP_BGP-PEER" {
    logical_node_profile_dn = aci_logical_node_profile.SR-XXX_GLOBAL_L3OUT-L201_NP.id
    addr = "10.10.10.26/30"
    as_number = "24880"
    ctrl = "send-com,send-ext-com"
result:
qsnyder
Based on looking at the Terraform resource docs for that resource, it doesn't appear that one exists.
https://registry.terraform.io/providers/CiscoDevNet/aci/latest/docs/resources/bgp_peer_connectivity_profile
I can ask around internally and see if there is some other way of accomplishing this.
HTH.
q.
qsnyder
HTH.
q.
