ron.whitt
Hello experts,
I am trying to install the ncs-5.3.1.1-cisco-etsi-nfvo-4.2.0-bundle for NSO (version 5.2.0.3, local install under ~/ncs-run)
I can get all the other packages to load and compile, but for the cisco-etsi-nfvo package, there isn't a Makefile under /src.
I tried loading the packages without compiling the cisco-etso-nfvo package, but NSO throws this error:
>>> System upgrade is starting.
>>> Sessions in configure mode must exit to operational mode.
>>> No configuration changes can be performed until upgrade has completed.
>>> System upgrade has been cancelled.
Error: Internal error: {failed,
{recompile_needed,
"./state/packages-in-use/1/cisco-etsi-nfvo/load-dir/etsi-nfv-descriptors.fxs"}}
But... no makefile... no compile.
Any  help or guidance would be appreciated.  if someone has the makefile, maybe post that and I'll copy it into the build.
1 Comment
sunge
The ncs-5.3.1.1-cisco-etsi-nfvo-4.2.0-bundle is pre-compiled to run on NSO 5.3.*, hence the
error you are seeing.
We do not ship source code with NFVO, so you cant re-compile it.
You need to get NFVO the is pre-build for NSO 5.2.
I hope this answers you question.
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
