Jan Lindblad
NSO 4.5 is out!
Read the CHANGES file below. Or click the link below to see NSO 4.5 tagged posts here on the Hub. For example Jacob's series on the new NSO Web UI. More 4.5 news posts are on the way.
https://communities.cisco.com/search.jspa?q=nso-4.5&place=/places/531930&depth=ALL
NSO 4.5 CHANGES file:
NSO-4.5 [October  6, 2017]
Deprecation notice:
  - Toolchain: pyang will be removed from NCS in a
    future release.  If you need pyang, we recommend that you download the
    latest version of pyang from github (https://github.com/mbj4668/pyang).
    (Issue tracker: #26851)
Removals:
  - ncs: It is no longer possible to upgrade directly from NCS 2.3.x or
    older version. If such need exists, the upgrade needs to be done in two
    steps: from NCS 2.3.x to NSO 4.4, and then to the desired more recent
    version.
  - Documentation: The user guide previously mentioned a possibility to
    login via JSON-RPC and re-use the resulting session cookie for REST and
    RESTCONF requests, this has been removed.
    (Issue tracker: #26857)
  - Python API: The module _ncs.deprecated.maapi has been removed.
Non-backwards compatible enhancements:
  - ncs: The internal representation of leaf-lists has changed.  Leaf-lists
    now behave similar to lists in terms of operations, i.e., individual
    elements can now be created and deleted instead of setting/deleting the
    entire leaf-list as a single entity. Attributes can be set on
    individual leaf-list elements which removes previous limitations on how
    service code can be written allowing individual leaf-list elements to
    be shared by multiple services.
    = Highlights =
    * create(), sharedCreate() and delete() can now be used on individual
    leaf-list elements. This affects the following APIs:
    * Java
    * Python
    * JSON-RPC
    * Erlang
    * C
    * Attributes can be set on individual leaf-list elements. It also
    means that FASTMAP will store a refcount and a list of backpointers per
    individual leaf-list element when service code uses sharedCreate() to
    deploy a leaf-list entry.
    * NavuLeafList can now be used to manage leaf-list YANG nodes in Java
    NAVU API. Please refer to the JavaDoc for com.tailf.navu.NavuLeafList.
    * For convenience, previous operations for setting/deleting whole
    leaf-lists still exist, but the semantics are somewhat different. In
    terms of actual operation these will result in a series of create and
    delete operations of leaf-list elements, which will result in a
    different view when iterating over a changeset.
    * `diffIterate` will report create/delete for leaf-list elements
    instead of set/delete for the whole leaf-list (see notes on backwards
    compatibility below).
    * Data providers will get invocation of
    `iterator()`/`existsOptional()`/`create()`/`remove()`/`numInstances()`/
    `moveAfter()` data callbacks for individual leaf-list elements instead
    of `getElem()`/`setElem()`/`remove()` for the whole leaf-list (see
    notes on backwards compatibility below).
    * Entries in `audit.log` will now show individual create and delete
    for leaf-list elements.
    == Migration ==
    * While operations for setting/deleting whole leaf-lists still exist,
    they should be seen as convenience and be changed in the long run to
    the new operations.
    * Usage of NavuLeaf for managing leaf-list nodes in Java code should
    be replaced by the new NavuLeafList API. Even though NavuLeaf is still
    supported for backwards compatibility, but since it relies on
    setting/deleting the whole leaf-list operations it should be replaced
    in the long run.
    * Code doing iteration on changesets, e.g., subscribers need to be
    changed to expect create/delete on leaf-list elements. As a stop gap
    measure one can use a newly introduced (and deprecated) flag to get the
    old behaviour. This change should be minimal, but please note that
    there are limitations.
    * Data providers need to be changed to expect different data callback
    invocations as described above. As a stop gap measure one can use a
    newly introduced (and deprecated) flag to get the old behaviour.
    == Backwards compatibility ==
    Certain operations can be made to run in a backwards compatibility
    mode, making them behave as before, i.e., handling leaf-lists as single
    elements. The flags for controlling this behaviour are deprecated,
    meaning that they will be removed in a future release.
    * For the iteration functions in the CDB and MAAPI APIs, the flag
    ITER_WANT_LEAF_LIST_AS_LEAF can be used to get the old behaviour, see
    the JavaDoc for com.tailf.conf.ConfIterateFlags and
    com.tailf.conf.DiffIterateFlags.
   * For data providers, annotation @DpFlags(leafListAsLeaf = true) can
    be used to get the old behaviour, see the JavaDoc for
    com.tailf.dp.annotations.DpFlags.
    == Limitations ==
    * There is no option to downgrade to a previous version of NSO. See
    `ncs-backup(1)` regarding backup procedures.
    * CDB subscribers on slaves cannot use the backwards compatibility
    flag for iteration.
    * If transactions on leaf-lists conflict with each other, iteration
    might produce unexpected results due to a set/delete on the whole list
    actually being composed of individual create/delete operations.
    * At the moment it is not possible to see attributes on leaf-list
    elements in CLI using | display service-meta-data. It is possible to
    see attributes in XML format using | display xml.
    == Examples ==
    Several examples have been rewritten to show usages of new interfaces
    for leaf-lists. Specific examples to look at might be (under
    examples.ncs/getting-started/developing-with-ncs):
    * `4-rfs-service`
    * `18-simple-service-erlang`
    * `23-new-leaf-list-upgrade`
    (Issue tracker: #17868, #18557, #18980, #19136, #19177, #20326, #21179,
     #24027, #25379, #27130, #27112, #27789, #28594, #28932)
  - ncs: Improve consistency and clarity in audit logging.
    * Src IP and port, protocol and context have been added to audit log
    messages.
    * Wording in audit log messages have been changed to be consistent and
    clearly differentiate between authentication attempts (and methods) and
    the final login result.
    * A number of logsyms have changed named or been removed
    The following logsyms are new (due to renaming): *
    `LOCAL_AUTH_SUCCESS` * `LOCAL_AUTH_FAIL` * `PAM_AUTH_SUCCESS` *
    `PAM_AUTH_FAIL` * `EXT_AUTH_SUCCESS` * `EXT_AUTH_FAIL` *
    `AUTH_LOGIN_SUCCESS` * `AUTH_LOGIN_FAIL` * `AUTH_LOGOUT`
    The following logsyms have be renamed or removed (due to no longer
    being used): * `BAD_LOCAL_PASS` * `NO_SUCH_LOCAL_USER` *
    `PAM_LOGIN_FAILED` * `PAM_NO_LOGIN` * `EXT_LOGIN` * `EXT_NO_LOGIN` *
    `SSH_LOGIN` * `SSH_LOGOUT` * `SSH_NO_LOGIN` * `WEB_LOGIN` *
    `WEB_LOGOUT`
  - ncs: Input parameters to actions and rpcs are now validated with
    respect to all constraints specified in the YANG model. A side effect
    of this change is that empty non-'presence' containers in the input are
    never passed to the action/rpc implementation, regardless of whether
    they were provided in the invocation.
    (Issue tracker: #26216, #27243, #27609, #28164, #29275)
  - ncs: For devices the with want-reverse=true the reverse diff is now
    sent when the device fails in the commit queue.
  - ncs: NSO now gives warnings at startup or package reload when it looks
    "suspicious", i.e. may break some functionality. Currently the
    following scenarios will trigger the warnings, with more scenarios
    likely to be added in the future:
     - one or more namespaces are removed by the upgrade
    - there are source .java files found in the package, but no matching
    .class files in the jars loaded by NSO
    - there are matching .class files with modification time older than
    the source files, which hints that the source has been modified since
    the last time the package has been compiled
    If a warning has been triggered it is a strong recommendation to fix
    the root cause. If all of the warnings are intended, it is possible to
    proceed with "packages reload force" command when the upgrade is done
    at runtime or --with-package-reload-force flag or
    NCS_RELOAD_PACKAGES=force environment variable at startup.
    Note that this is not a strict upgrade validation, but only intended
    as a hint to NSO administrator early in the upgrade process that
    something might be wrong. The usual upgrade procedure must still be
    followed as described in NSO Administration Guide -> NSO Deployment ->
    NSO system and packages upgrade.
    (Issue tracker: #23121)
  - ncs: Added /devices/commit-queue/queue-item/failed.
  - ncs: NSO now displays the path that is out of sync in the no-overwrite
    error message.
  - ncs: When doing 'commit dry-run' with native format you can now also
    get the reverse operations by adding the commit parameter 'reverse'.
    This is the change-set for getting back to the current running state in
    the network if the commit is successfully executed. Be ware that if any
    changes are done later on the same data the reverse change-set returned
    is then invalid.
    (Issue tracker: #26955)
  - ncs: Added time-based job scheduler suitable for scheduling periodic
    background work.
    Under /scheduler tasks can be configured to trigger actions on a given
    instance. The periodicity of the tasks is configured with standard
    Vixie Cron expressions.
    For new installations a default task is configured to run the
    'prune-completed-queue-items' action under
    /devices/commit-queue/completed each day pruning all completed queue
    items that are older than a day.
  - ncs: Previously when a device was in the completed list in a commit
    queue item meant that the device had been processed, not necessarily
    that the device modifications were pushed to the network (if any of the
    devices in the queue item had failed). It now means that a device is
    completed when its device modifications are pushed to the network. This
    is consistent through the commit queue notifications in the ncs-events
    stream and the following lists:
    /devices/commit-queue/queue-item/completed
    /devices/commit-queue/completed/queue-item/completed
    /deviecs/commit-queue/queue-item/completed
    For commit queue notifications the failed-devices list in a
    notification with executing status now only reports new failed devices
    instead of all failed devices for the queue item.
    Added /devices/commit-queue/completed/queue-item/completed-services
    and devices/commit-queue/completed/queue-item/failed-services.
  - ncs: To simplify template syntax when optional nodes are set using
    template variables, and to allow for more backwards compatibility with
    previous versions which did not allow setting empty string values using
    templates, the semantics of a tag consisting solely of empty variables
    has changed to its original meaning, i.e. to skip the node instead of
    setting an empty string value. This does not apply to XPath expressions
    including variables that result in an empty string value, so if an
    empty string value is desired an XPath variable can be surrounded with
    string(). For example:
     - <some-tag>{$EMPTY}</some-tag> <!-- the tag will be unset -->
    - <some-tag>{$EMPTY}{$OTHEREMPTY}</sometag> <!-- also unset -->
    - <some-tag>{string($EMPTY)}</sometag> <!-- the tag will be set to ""
    (Issue tracker: #28735)
  - CLI: If the prompt contained vt100/xterm control sequences, for example
    for setting the xterm title, then those characters would be counted as
    part of the prompt and the error indication arrow would be misaligned.
   This has now been fixed such that many control sequences are
    automatically recognized and ignored. Also, two new magical sequences:
    \[ and \] has been added. They can be used to indicate that the
    characters in between should be ignored when calculating the width of
    the prompt. However, any prompt already containing \[ or \] need to
    change to [ and ] respectively. Previously \[ and \] would be
    completely equivalent to [ and ].
    (Issue tracker: #29480)
  - JSON-RPC: get_schema now returns children list for types that can have
    children, even if no child exist.
  - Python API: logging has been updated to match the format of existing
    NSO log files.
    (Issue tracker: #28782)
  - Toolchain: The algorithm that generates integer values for YANG
    identifiers has been modified to generate a different value for the
    first identifier in each line below, to avoid the conflict with the
    second identifier in the same line. Thus it is no longer necessary to
    use tailf:id-value for any of these identifiers to avoid the conflicts,
    and it is recommended to remove any existing tailf:id-value statements
    for them.
    community-id unit
    lag_id protocol-operation
    fabric-interfaces if-name-str
   ejpol-items last-received
    isis-context-information redundancy-events
    si-nat-icmpv6-errors-local-nptv6 in-octets
    tBgpInstanceParamsExtTblLstCh tos-type-info
    (Issue tracker: #30064)
Enhancements:
  - ncs: A new YANG extension, tailf:ned-default-handling ''mode'', has
    been added. If used it will override the NED's native default handling
    mode for that leaf.
    (Issue tracker: #25189)
  - ncs: The kickers are enhanced with a notification-kicker that makes it
    possible to trigger on received netconf notifications. For more on this
    see the development guide.
  - ncs: NSO now uses "CiscoSSL", a Cisco-enhanced version of OpenSSL
    (currently based on OpenSSL 1.0.2k), for cryptographic functions.
    (Issue tracker: #20900)
  - ncs: New Yang annotation: tailf:ned-ignore-compare-config that can be
    used to remove a changed leaf from compare-config.
    For the tailf:aes-cfb-128-encrypted-string and the
    tailf:des3-cbc-encrypted-string type, proper decryption/encryption will
    be made of the data exchanged with a Netconf device.
    (Issue tracker: #25826)
  - ncs: It is now possible to execute commit dry-run outformat native
    without establishing connection to the actual device. NEDs need to
    implement this feature. It is implemented in NSO for NETCONF and SNMP
    devices, while CLI and generic NEDs will by default fall back to the
    previous behaviour which is to establish connection to the device.
    In order to be able to execute commit dry-run outformat native offline
    the implementation for NETCONF and SNMP devices requires the
    capabilities of the device to be known, i.e. /devices/device/capability
    list to contain relevant entries. This list is populated when
    connecting to the device for the first time, or it can be manually
    populated with add-capability or copy-capabilities actions. Other NEDs
    (CLI or generic) implementing this feature might not have this
    requirement, or have other requirements.
    (Issue tracker: #25280)
  - ncs: It is now possible to specify a "guard" for an insert operation on
    ordered-by user list and leaf-list in service or API templates. A guard
    identifies a range of elements in ordered-by user list or leaf-list so
    that if all of the target elements to be inserted already exist in the
    same order within this range, then their current position is preserved.
    This is useful to avoid reordering a list or a leaf-list every time a
    service is re-deployed, while being able to impose constraints on
    elements' position in the list or leaf-list.
  - ncs: Data kickers are now validated agains the YANG schema. The leaves
    'monitor', 'trigger-expr' and 'kick-node' must comply to the YANG
    models.
  - ncs: The ncs-commit-queue-progress-event notification has now
    additional information about completed and failed services as a result
    on completed or failed commit queue items. The corresponding
    ca_progress events that can be subscribed to by northbound notif
    interface are also extended with the same information.
  - ncs: The NOTIF_COMMIT_DIFF event now also includes the "comment" and
    "label" given for the commit (if any) - they can be retrieved with the
    CommitDiffNotification.getComment() and
    CommitDiffNotification.getLabel() methods.
    (Issue tracker: #27664)
  - ncs: The --erlang-application-name parameter to ncs-make-package now
    defaults to the package name.
  - ncs: To guarantee service integrity NSO now checks for overlapping
    service or device modifications when committing with the commit queue.
    These checks can be bypassed by setting the
    /ncs:devices/global-settings/commit-queue/error-recovery/mode to
    unsafe. This could potentially commit changes that are not deployed to
    the network if a queue item with overlapping modifications failed ahead
    in the queue. The benefit of doing so is increased throughput. The mode
    is configured on a per node basis.
    NSO now serializes re-deploys through an internal re-deploy queue.
    This is an optimization for RFM loops where multiple re-deploys are
    requested in parallel. Several invocations of re-deploy can then be
    skipped. Another benefit is that a reactive-re-deploy can wait for
    commit queue items with overlapping modifications to finish instead of
    failing in such scenario.
  - ncs: SNMP NED now supports partial-show. Also fixed a bug where a
    sync-from an SNMP device would sometimes fail in certain combinations
    of loaded NSO packages.
  - ncs: NSO now restricts reading configuration from a device in the
    'compare-config' action when some other configuration is writing to it.
    This is to avoid getting inconsistent data when reading the
    configuration. A 'wait-for-lock' parameter has been added to the action
    that can be used to specify a timeout that the action waits until the
    device lock is released and any commit queue items that contain the
    device are done. If the 'wait-for-lock' parameter is not specified, the
    action will fail immediately for the device if the lock is taken for
    the device or if the device is placed in the commit queue.
    (Issue tracker: #29234, #29531)
  - ncs: A new command, templatize, has been added. It is used to extract
    configuration templates from existing configurations by looking for
    patterns.
  - ncs: NSO now tries to reconnect to the device is the connection has
    been dropped while calculating the reverse diff-set in the abort phase
    of the transaction.
    (Issue tracker: #29178)
  - CDB: NETCONF notification subscription status was changed from internal
    callpoint to operational CDB data. This to be able to subscribe for
    changes.
  - CDB: It is now possible to give data kickers priorities, 0-255,
    deciding order of execution when multiple data kickers triggers at the
    same time. Also, it is possible to serialize data kickers by
    configuring a serialization number; 0-255. Also, it is possible to give
    notification kickers priorities, 0-255, deciding order of execution
    when multiple notification kickers triggers at the same time.
  - CLI: Added /ncs-config/cli/mode-info-in-aaa to ncs.conf.
    /ncs-config/cli/mode-info-in-aaa is either "true", "false" or "path",
    If "true", then all commands will be prefixed with major and minor mode
    name when processed by the AAA-rules. This means that it is possible to
    differentiate between commands with the same name in different modes.
    Major mode is "operational" or "configure" and minor mode is "top" in
    J-style and the name of the submode in C- and I-mode. On the top-level
    in C- and I-mode it is also "top". If set to "path" and if the command
    operation is "read" the major mode will be followed by the path to the
    submode which will be followed by the command. If set to "path" and if
    the command operation is "execute" the major mode will instead be
    followed by the command and the path to the submode will be prepended
    to any path arguments of the command.
    (Issue tracker: #29276)
  - CLI: 'select' and 'de-select' are now available as pipe commands when
    displaying the configuration in operational mode (eg. 'show
    running-config') in the I-style CLI.
    (Issue tracker: #28877)
  - Cluster: Upgrade performance has been improved on service node in
    cluster.
    (Issue tracker: #25860)
  - Cluster: NSO now gives an error if /cluster/commit-queue/enabled is not
    set when committing to the commit queue with an LSA device.
    Improved subscription failure alarm for ncs-events stream.
    (Issue tracker: #29665)
  - Documentation: EXAMPLES: The packages used in example
    service-provider/virtual-mpls-vpn now have a '-example' suffix to
    clarify that the packages are just examples and not production ready
    packages. The documentation in the NSO Development chapter has been
    updated with this information as well.
  - Java API: Japi Dp - when a Dp daemon started it would previously start
    5 worker threads as the min value for the worker threadpool. This min
    is now changed to 1 thread.
    (Issue tracker: #29565)
  - JSON-RPC: Extend show_config method with optional parameters result_as
    string|json and with_oper true|false
  - NETCONF: The NSO NETCONF server now supports the RFC 5717 partial-lock
    capability.
  - Python API: It was not possible to e.g. call an action from inside
    another action or service if they were both registered to the same
    ncs.dp.Daemon. This has been fixed.
  - Python API: Support for accumulate functionality in NSO data providers
    has been added.
    (Issue tracker: #27320)
  - REST API: Added RESTCONF API according to
    draft-ietf-netconf-restconf-18. As a result, the existing REST API has
    got an improved json encoding, which may cause backward incompatible
    changes.
  - Smart Licensing: The NSO smart licensing integration now supports
    configuration of proxy servers.
  - Smart Licensing: The NSO Cisco Smart Licensing integration has been
    upgraded to support Java 9.
  - SNMP Agent: If any of the MIB models that hold configuration for the
    SNMP-TARGET-MIB, SNMP-USER-BASED-SM-MIB) is annotated with a callpoint
    (and consequently implemented by an external data provider) the SNMP
    Agent must re-read the configuration for any changes to take effect.
    This has previously been achieved by disabling and re-enabling the SNMP
    Agent. A new MAAPI function has been added for triggering the SNMP
    Agent to re-read its configuration - maapi_snmpa_reload().
    (Issue tracker: #24426)
  - Toolchain: The script "netconf-console" now accepts the command line
    parameter "--start-time" and "--stop-time" to be used together with
    "--create-subscription".
    (Issue tracker: #26653)
  - Web UI: Introducing webui-one. A react based user interface that will
    replace the previous XWT-based version. Webui-one contains a number of
    stand alone applications, such as:
    == Model browser ==
    * Helps you browse and access all data models loaded into the NSO.
    == Configuration editor ==
    * Browse data models and change configuration values.
    == Commit manager ==
    * Examine your transaction, look at diffsets and commit your changes.
    == Device manager ==
    * Find, synchronize and group your devices. Monitor connectivity status
      and access the configuration data.
    == Service manager ==
    * Find and synchronize your services. See deployment status
      and access the service configuration data.
    More applications will be added in future releases and users can add
    their own.
Non-backwards compatible corrections:
  - Building: ncsc / yanger now checks if a definition references something
    with a "lesser" "status" (e.g., if a "current" leaf uses a "deprecated"
    typedef).
    (Issue tracker: #28373)
  - Java API: Previously an item with declared tailf:id-value larger than
    2^31 was not correctly handled. This has been fixed.
    (Issue tracker: #27560, #27874, #29613)
  - JSON-RPC: get_schema levels parameter now apply to list schema entries.
    (Issue tracker: #28305)
  - JSON-RPC: commit with flags dry-run=native output changed to a list of
    objects with device and diff keys set to support determining which
    device the diff affected.
    (Issue tracker: #27778, #27708)
  - JSON-RPC: get_schema returned incomplete list of children for action
    output. This has been corrected.
  - JSON-RPC: access rules returned from get_schema now more closely
    reflect which operations are allowed.
    (Issue tracker: #22865)
  - JSON-RPC: get_value no longer qualify identityref values unless there
    is a conflict.
  - Python API: Service and Action now execute requests in separate threads
    improving parallelism.
    (Issue tracker: #28242)
  - Python API: add tctx to experimental DataCallbacks handler and improve
    support for leaf-list.
Corrections:
  - ncs: Re-deploying a service using a NED having the default handling
    mode 'report-all' would in some cases cause the device to be out of
    sync. This has been fixed.
  - ncs: Previously when doing an XPath query through a JSONRPC request and
    specifying a context node with an empty key an internal error would
    occur. This has now been fixed.
    (Issue tracker: #27063)
  - ncs: During a deep-check-sync operation NSO could complain about failed
    'when' expressions in an internal transaction used to evaluate the
    result. This has been fixed so the 'when' expression are not checked
    due to temporary nature of such transaction.
    (Issue tracker: #26973)
  - ncs: When writing kicker monitors in XPath format, augmented namespaces
    were not always handled correctly. This has been fixed.
    (Issue tracker: #27939, #29180)
  - ncs: If an invalid namespace has been declared for a prefix in an XML
    template, this would result in an internal error. This has been fixed
    to produce a proper error message.
    (Issue tracker: #27513)
  - ncs: Previously for CLI and generic NED devices NSO could overwrite
    list entries that were created out-of-band even though the
    'no-overwrite' commit parameter was set. This has now been fixed.
  - ncs: Action including leaf-list could make the CLI crash on tab
    completion. This has now been fixed.
    (Issue tracker: #29471)
  - ncs: Previously for a NETCONF device with
    ned-settings/use-confirmed-commit=false a get-config was issued when a
    transaction aborted to calculate the reverse diffset between CDB and
    the device. This could result in that any out-of-band changes done on
    the device was overwritten. This has now been fixed.
    (Issue tracker: #29432)
  - ncs: Time to execute Maapi.setValues() used to grow quadratically with
    the size of the provided ConfXMLParam array. This has been fixed so the
    growth is now linear.
  - ncs: If a list had a sub-list with a 'when' expression, and a list
    entry and sub-list entries were created, and an additional change made
    the 'when' evaluate to false, all in the same transaction, the sub-list
    entries were not actually deleted. This has been fixed.
  - AAA: When PAM authentication was used, and REST or RESTCONF requests
    were made continuously with an interval of less than 10 seconds, the
    amount of memory used by the PAM interface process 'epam' could grow
    without bounds. This has been fixed - the amount of memory used by
    'epam' is now limited in this scenario.
    (Issue tracker: #29648)
  - Building: ncsc now allows a module to annotate statements defined in
    the same module.
    (Issue tracker: #29738)
  - Building: The ietf-yang-library-ann.yang module, which annotates a
    callpoint to ietf-yang-library.yang, was not included in the release.
    (Issue tracker: #29856)
  - C-API: The confd_ha_connect() function could in some cases write a NUL
    character outside an array on the stack. This has been fixed.
    (Issue tracker: #26979)
  - CDB: Fix bug when setting an operational choice using MAAPI. Changing
    the case value did not work as intended when using an ordinary
    transaction (allowing writes to both config true and false data).
    Using an operational (config false) only transaction was not affected.
  - CDB: Fix a bug which might crash NSO during upgrade (in `phase0`).
    Calling `cdb_get` on a non existing path could crash NSO under certain
    circumstances when trying to format an error message including the non
    existent path.
    (Issue tracker: #29075)
  - CLI: When doing package upgrading, and then "commit dry-run outformat
    cli", an error was encountered in certain cases. This has been fixed.
    (Issue tracker: #17605, #20971, #24538, #25131, #26103, #25639)
  - CLI: Add missing <cr> for '?' when displaying completion for leaf-list
    type.
    (Issue tracker: #22307)
  - CLI: Combining lists with tailf:cli-sequence-commands and
    tailf:cli-compact-syntax the CLI could miss printing out some data
    nodes. This has been fixed.
    (Issue tracker: #25367)
  - CLI: When using leaf-refs in the data model and trying to get info
    using '?' or <TAB> in the CLI the CLI appears non-responsive. This has
    been fixed.
    (Issue tracker: #26727)
  - CLI: When combining the clispec-options noDuplicate and auditLogHide
    the CLI couldn't recognise if certain executions was or wasn't
    different. Thus it would block the launcher even when it wasn't
    necessary. This has been fixed.
    (Issue tracker: #24086)
  - Java API: Setting a leaf or leaf-list to a value containing unicode
    characters could fail with internal error. This has been fixed.
    (Issue tracker: #27066)
  - Java API: XML namespace declarations are now taken into account when
    producing ConfXMLParam array with NavuParser.
    (Issue tracker: #29637)
  - Java API: Fixed NavuParser in java to handle empty string value.
  - JSON-RPC: The JSON-RPC method "subscribe_cdboper" could not handle
    subscriptions to paths adorned when statements. This has been fixed.
    (Issue tracker: #23246)
  - JSON-RPC: When calling an action through the 'run_action' method and
    the action was broken in such a way that it returned something other
    than was specified in the yang file, the session would be terminated
    and all subsequent calls on that session would fail (in the WebUI you
    would be logged out). This has been fixed.
  - JSON-RPC: Nodes that contained a "when" expression were always
    displayed, no matter how the "when" expression evaluated. This has been
    fixed.
  - JSON-RPC: The webui now shows which devices are affected from a commit
    dry-run.
    (Issue tracker: #27708)
  - JSON-RPC: get_schema on an action augmented from a different namespace
    would fail. This has been corrected.
    (Issue tracker: #28976)
  - JSON-RPC: run_action now supports augmented input parameters. Use
    prefix:tag if disambiguation of tag is required.
    (Issue tracker: #29616)
  - JSON-RPC: Calling get_schema with insert_values = true on a tree with
    an augmented case failed if the augmented case was currently active.
  - JSON-RPC: set_value incorrectly used create instead of update operation
    when verifying NACM rules in most cases. This has been corrected.
  - JSON-RPC: get_schema did not include qname for case entries. This has
    been corrected.
  - NED: Mandatory leaves could cause 'compare-config' to show a non-empty
    diff while in fact there is no diff. This has now been fixed.
  - NETCONF: If a leaf with a default value in the data model was deleted,
    the NETCONF server now generates a proper "netconf-config-change"
    notification.
  - Python API: _ncs.maapi.diff_iterate() didn't report MOP_ATTR_SET and
    MOP_MOVED_AFTER correctly. This has been fixed.
  - Python API: Python VM log files was not re-opened when issuing
    reopen_logs command, this has been fixed.
    (Issue tracker: #28777)
  - Python API: When calling the function _ncs.ha.status() the Python API
    could leak some memory. This has been fixed.
    (Issue tracker: #29666)
  - REST API: REST Query of an 'inline' empty leaf caused all config to be
    returned. This has been fixed.
    (Issue tracker: #28517)
  - RESTCONF: Authentication failures did not return a RESTCONF error
    response. This has been corrected.
    (Issue tracker: #29399)
  - RESTCONF: The RESTCONF example had errors in the instructions, these
    are now fixed.
  - RESTCONF: The YANG model 'ietf-restconf' is now available for retrieval
    over REST and RESTCONF.
    (Issue tracker: #29571)
  - Toolchain: pyang --tailf-sanitize crached if it found some
    tailf:symlinks.  This bug has been fixed.
  - Web Server: The default absolute timeout has now been extended to 16
    hours.
  - Web Server: When the docroot tag was not specified, the resulting file
    system path constructed in webui_appmod_hatchery was invalid, which
    caused the exception. This has been fixed.
  - Web UI: Leaf lists did not check the validity of added values. This has
    now been fixed.
    (Issue tracker: #27077)
  - Web UI: There was no way to clear some input parameters in the action
    input fields. This has now been fixed with a "Reset parameters" button
    that clears all input parameters
    (Issue tracker: #27915)
  - Web UI: The user had to reload the page to see leafs with a when
    expression where the leaf and the when target were on the same page.
    (Issue tracker: #27977)
  - Web UI: WebUI Prime failed to initialize if amd.less or amd.js could
    not be loaded correctly. This has been fixed.
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
