Basic WCCP troubleshooting: an simple example
6842
pevaneyn
It is difficult to write a document that is more complete then the troubleshooting WCCP entry However that document doesn't give a guide on how to troubleshoot WCCP.
In this post we will solve a basic WCCP issue and we will explain all the steps along the way.
Before I can show you the problem I need to fix out lab. We have a WCCP cluster containing cdn-wave-574-1 and cdn-wave-574-2. When logging in I see:
cdn-wave-574-1#show wccp routers
Router Information for Service: TCP Promiscuous 61
Routers Seeing this Wide Area Engine(0)
-NONE-
Routers not Seeing this Wide Area Engine
172.16.1.1
Routers Notified of from other WAE's
-NONE-
Multicast Addresses Configured
-NONE-
and
cdn-wave-574-2#show wccp routers
Routers Seeing this Wide Area Engine(1)
Router Id       Sent To         Recv ID     KeyIP        KeyCN  MCN
192.168.50.45 172.16.1.1 0007FF4C    10.48.68.201   12063     21711
-NONE-
-NONE-
-NONE-
So on cdn-wave-574-1 we have a problem: we don't talk to the router.  First thing to check is the configuration:
cdn-wave-574-1#show run | i wccp
wccp router-list 1 172.16.1.1
! default wccp mask is src-ip-mask 0xf00 dst-ip-mask 0x0
wccp tcp-promiscuous router-list-num 1 l2-redirect mask-assign assign-method-strict l2-return
wccp version 2
no wccp flow-redirect enable
cdn-wave-574-2#show run | i wccp
wccp version 2
That looks identical and thus ok. Can we ping the router?
cdn-wave-574-1#ping 172.16.1.1
PING 172.16.1.1 (172.16.1.1) 56(84) bytes of data.
From 172.16.1.2 icmp_seq=3 Destination Host Unreachable
From 172.16.1.2 icmp_seq=5 Destination Host Unreachable
--- 172.16.1.1 ping statistics ---
5 packets transmitted, 0 received, +2 errors, 100% packet loss, time 4000ms
cdn-wave-574-2#ping 172.16.1.1
64 bytes from 172.16.1.1: icmp_seq=1 ttl=255 time=0.404 ms
64 bytes from 172.16.1.1: icmp_seq=2 ttl=255 time=0.396 ms
64 bytes from 172.16.1.1: icmp_seq=3 ttl=255 time=0.448 ms
64 bytes from 172.16.1.1: icmp_seq=4 ttl=255 time=0.400 ms
64 bytes from 172.16.1.1: icmp_seq=5 ttl=255 time=0.813 ms
5 packets transmitted, 5 received, 0% packet loss, time 4002ms
rtt min/avg/max/mdev = 0.396/0.492/0.813/0.162 ms
Hmm. Do we have a MAC for that IP?
cdn-wave-574-1#show arp | i 172.16.1.1
Internet  172.16.1.1       INV        00:00:00:00:00:00 ARPA  GigabitEthernet1/0
No we don't. Why?
cdn-wave-574-1#show interface GigabitEthernet 1/0  | i Link
Link State: Interface is up,line protocol down
Aha. No cable. Please note that the magic command also gives this information:
cdn-wave-574-1#test self-diagnostic all
running test `basic'
running test `connectivity'
running test `interfaces'
running test `tfo'
running test `wccp'
running test `inline'
running test `system'
running test `wafs'
running test `application-security'
Diagnostic Report performed on 2/21/2011 9:55:9
Test PASS  [basic]
Test PASS  [connectivity]
Test WARN  [interfaces]
     WARN  IFACE_LINK_DOWN  Interface GigabitEthernet 1/0 line protocol is down.
     Action:
     Check the cable connectivity to switch/router.
Test PASS  [tfo]
Test FAIL  [wccp]
     WARN  UNREACHABLE      WCCP router 172.16.1.1 is not reachable
     Action:
     Check if configured address is correct and/or there're no network connectivity issues.
     FAIL  UNREACHABLE      No WCCP routers are reachable
     Action:
Test NONE  [inline]
     NONE  -                Skipping test because inline card(s) is not present
Test WARN  [system]
     WARN  HAS_ALARM        3 Major Alarms are raised in the device.
Please find the list below.
1.     WCCP router 172.16.1.1 unreachable for service id: 61.
2.     WCCP router 172.16.1.1 unreachable for service id: 62.
3.     The Flow Monitor control connection to the tcpstat-v1 console could not be (re)established after multiple attempts.
     Action:
     Critical/major alarms are raised. Check device alarms using 'show alarms detail' cli command for details.
Test NONE  [wafs]
     NONE  -                Skipping test because Wafs is not enabled
Test PASS  [application-security]
Next week we will handle a case of mistaken identity. See you then.
Content for Community-Ad
