decommissioning a single cisco switch Cisco catalyst 9300
2837
amir83
Beginner
What is the step by step procedure to decommissioning a single cisco catalyst switch.
6 Comments
balaji.bandi
VIP Master
Disconnect from the network, erase the config or reset to factory - so you can install any other place ? is this what you looking ?
actory-reset { all | config | boot-vars}
Example:
Device# factory-reset all
Use the command with all options enabled.
No system configuration is required to use the factory reset command.
Use the option all to erase all the content from the NVRAM, all the Cisco IOS images including the current boot image, boot variables, startup and running configuration data, and user data.
Use the option config to reset the start-up configurations.
Use the option boot-vars to reset the user added boot variables.
After the factory reset process is successfully completed, the device reboots and stops at ROMMON mode.
amir83
Beginner
what are the steps to disconnect from the network and then power it down and take it out from the rack:
Please let me know these are correct steps:
SW1> show sw
Switch/Stack Mac Address : f86b.d963.6300 - Local Mac Address
Mac persistency wait time: Indefinite
H/W Current
Switch# Role Mac Address Priority Version State
*1 Active f811.f963.9500 1 V03 Ready
> conf t
> no switch 1 provision
>end
balaji.bandi
VIP Master
if only 1 switch - there is no active ports
1. Turn off the device
2. remove all connected cables.
3. bring back to the desk, connect to console - turn on the switch.
4. reset to factory.
amir83
Beginner
There are active ports, so I should turned off all of the active ports and then:
balaji.bandi
VIP Master
There are active ports, you need to Move to other Switch, since you thinking to remove them.
By turn off the devive, all working devices go offline.
you can unpatch while removing the kit from the rack anyway.
rest all same procedure.
hope this makes sense?
Note: when we addressing decomm means, all active devices gone from the device and migrated to a new device or alternative option or vacated.
amir83
Beginner
Thank  you all for the info.
