Disconnect from the network, erase the config or reset to factory - so you can install any other place ? is this what you looking ?
actory-reset{all|config|boot-vars}
Example:
Device# factory-reset all
Use the command with all options enabled.
No system configuration is required to use thefactory resetcommand.
Use the optionallto erase all the content from the NVRAM, all the Cisco IOS images including the current boot image, boot variables, startup and running configuration data, and user data.
Use the optionconfigto reset the start-up configurations.
Use the optionboot-varsto reset the user added boot variables.
After the factory reset process is successfully completed, the device reboots and stops at ROMMON mode.
what are the steps to disconnect from the network and then power it down and take it out from the rack:
Please let me know these are correct steps:
SW1> show sw
Switch/Stack Mac Address : f86b.d963.6300 - Local Mac Address Mac persistency wait time: Indefinite H/W Current Switch# Role Mac Address Priority Version State ------------------------------------------------------------------------------------- *1 Active f811.f963.9500 1 V03 Ready
