Data Center Blogs
Developer Sustainability Week Events
Build for Better Code Challenge
Cisco U. Spotlight Registration
>> View previously featured conversations <<
Blog Articles
UCSD CIDR Calculator
Task NameCIDR CalculatorDescriptionGets the CIDR number from a subnet mask, pretty usefull to avoid to input both when some tasksneeds the subnet mask and other the CIDR.PrerequisitesTested on 5.1Cate...
0 Comments
Launch UCS KVM from a script
This blog was generated from CDN blog Created by: John McDonough on 02-08-2011 03:05:49 PMA KVM launch link for a UCS blade or rack mount server is accessible via the UCS Manager interface and the ur...
0 Comments
Automate the UCS CLI with expect
This blog was generated from CDN blog Created by: John McDonough on 11-05-2011 10:05:50 AMSometimes an API is not able to do everything that is needed by administrators. Occasionally there may be a t...
0 Comments
Simple Network Management Protocol (SNMP)
This blog was generated from CDN blog Created by: Sheryl Sage on 16-06-2010 12:44:50 AMUCS Manager 1.3 provides Simple Network Management Protocol (SNMP) unidirectional support for traps as an asynch...
0 Comments
UCS XML API "curl and xml"
This blog was generated from CDN blog Created by: John McDonough on 15-04-2010 11:18:43 PMLast time I wrote about using telnet to connect to the UCS Manager API as a way to introduce the API and show...
1 Comments
Getting UCS Manager and Blade Firmware Versions
This document was generated from CDN thread Created by: John Dove on 18-03-2013 10:12:29 AM I would like to generate a monthly script that compares the firmware of UCS Manager to the firmware of the b...
0 Comments
best way to query WWPN of all HBA
This document was generated from CDN thread Created by: EELCO NIEUWSTAD on 03-02-2012 02:07:24 AM Because I find it very boring (and I am lazy) to create aliases and zones for all HBA's of my server p...
0 Comments
Collect CPU speeds via UCS PowerTool...
This document was generated from CDN thread Created by: Sage Harvey on 14-05-2012 02:43:07 PM Hi all, I'm trying to get the CPU speed from the blades I have installed as part of an inventory script.  ...
0 Comments
UCS Health check HTML Report
This document was generated from CDN thread Created by: Jeremy Waldrop on 04-04-2012 06:06:32 AM Hey all, I have been working with the UCS PowerShell toolkit in the lab and have come up with a version...
0 Comments
Unable to load UCS Manager
This document was generated from CDN thread Created by: Alexander Green on 10-10-2011 04:40:59 PM Hello All, If this issue has already been addressed, please direct me to the correct place.  I'm runni...
6 Comments
2nd Fabric Interconnect shows inapplicable
This document was generated from CDN thread Created by: Shouyi Sun on 27-04-2011 07:59:34 AM Hi  I found the 2nd Fabric Interconnect shows "Fabric Interconnect Binapplicable".What does it mean? The fi...
0 Comments
This community is intended for developer topics around Data Center technology and products. If you are looking for a non-developer topic about Data Center, you might find additional information in the Data Center and Cloud community
