UPDATE: 2/21/18
*All TAPS Updated for CPO 3.5
*Added the following TAPs: Cisco Spark API, Pondering Automation Blog Examples
Hey all,
nothing much to say today... other than I've updated a lot of my API sets and automation packs and wanted to post them for you! If you need a version prior to 3.5, let me know via email and I'll see what I can do. Please note these are my developed/custom developed TAPs, come with NO SUPPORT, NO WARRANTY, and are fully opensource for you to use! Feel free, however, to ask me questions here or via email/etc.
You will find all the taps in one .ZIP file below. If you want one individually please send me a request. You can only attach 5 things per blog
They all require CPO 3.5 or later. Just download the taps and install them as needed. If you need help installing TAPs, refer to the CPO online documentation on TAP installation.
Automation Pack | Description | Version | Requires |
Automation Function Tools(AFT) | A collection of easy to use functions | 2.6.0.6 | TAPS: Core |
Base Queue Class | A basic queue system | 1.2.0.5 | N/A |
Content Logger | A package to help add logging to your processes/automations | 1.2.0.2 | TAPS: Core, AFT |
List Class | a basic list class in CPO | 1.0.0.5 | TAPS: AFT |
CPO NBWS Functions | Examples of CPO Northbound WebServices functions | 1.0.0.4 | TAPS: AFT |
JIRA API | API Set for JIRA - not all calls | 1.2.0.7 | TAPS: AFT, Core, Content Logger, Type class - Customer support case |
PO Rest API | Examples of CPO NBWS functions with REST | 1.0.0.7 | TAPS: AFT, Core, Content Logger |
Pondering Automation Examples | Just examples from the blogs | 1.0.0.1 | N/A |
Salesforce API | API set for Salesforce.com | 2.1.0.4 | TAPS: Core, Content Logger, Type class - customer support case |
SmartSheet API | API Set for SmartSheet.com | 1.0.0.6 | TAPS: AFT, Core, Content Logger, PO Rest API |
Cisco Spark API | API Set for Spark, not all calls yet | 1.0.0.2 | TAPS: AFT, Core, Content Logger |
Splunk API | API Set for Splunk Application | 2.2.0.3 | TAPS: AFT, Core, Content Logger |
Stack Class | A basic stack class | 1.0.0.5 | N/A |
Type Class - Customer Support Case | A basic class to handle adding data to support (or any) issues/cases | 2.1.0.2 | N/A |
Type Class - MS Access DB | A class to allow you to configure a MS Access as a DB target | 1.0.0.4 | Microsoft Jet OLEDB Driver installed to CPO |
Web Stock Example | An example showing grabbing stock quotes from the web | 1.0.0.3 | TAPS: Core |
Also here are some older blog posts that might be of value for you!
Pondering Automation Links | Cisco Communities
Additional Attachments:
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
