Amr_Elsherif
Description:
Fault delegate: A Fabric Node Group (fabricNodeGrp) configuration was not deployed on the fabric node 152 because: Node Not Registered for Node Group Policies
Type:
Config
Cause:
configuration-failed
Change Set:
deplSt:not-registered-for-fabric-node-group, forceResolve:yes, rType:mo, state:formed, stateQual:none, tCl:fabricNodeGrp, tType:mo
3 Comments
Amr_Elsherif
after remote leaf discovery and creating upgrade group for the new discovered leafs the above error shown.
Sergiu.Daniluk
You should open a discussion thread, not a blog post if you have a question.
Cheers,
Sergiu
Amr_Elsherif
Ok thanks
