09-27-2018 06:48 PM - edited 03-01-2019 06:08 AM
This document describes the steps to setup and configure ACI multi-site fabric from the scratch.
The ACI Multi-Site feature introduced in version 3.0 allows you to interconnect separate Cisco ACI Application Policy Infrastructure Controller (APIC) cluster domains (fabrics), each site that represents a different availability zone. This helps ensure multi-tenant Layer 2 and Layer 3 network connectivity across sites, and it also extends the policy domain end-to-end across fabrics. You can create policies in the Multi-Site GUI and push them to all integrated sites or selected sites. Alternatively, you can import tenants and their policies from a single site and deploy them on other sites.
Contributed by Linda Wang, Cisco TAC Engineer
1. Setup MultiSite Controller (MSC) by following the Cisco ACI Multi-Site Installation Guide below.
2. ACI fabrics have been fully discovered in two or more sites.
3. Make sure the APIC clusters deployed in separte sites have the Out of Band (OOB) management connectivity to the MSC nodes.
The hardware and software used in this example configuration is listed in the table.
Site A | |
Hardware Device | Logical Name |
N9K-C9504 w/ N9K-X9732C-EX | spine109 |
N9K-C93180YC-EX | leaf101 |
N9K-C93180YC-EX | leaf102 |
N9K-C9372PX-E | leaf103 |
APIC-SERVER-M2 | apic1 |
Site B | |
N9K-C9504 w/ N9K-X9732C-EX | spine209 |
N9K-C93180YC-EX | leaf201 |
N9K-C93180YC-EX | leaf202 |
N9K-C9372PX-E | leaf203 |
APIC-SERVER-M2 | apic2 |
IP Network(IPN) | N9K-C93180YC-EX |
Hardware | Version |
APIC | Version 3.1(2m) |
MSC |
Version: 1.2(2b)
IPN | NXOS: version 7.0(3)I4(8a) |
Note: The Cross-site namespace normalization is performed by the connecting spine switches, this would require the 2nd generation or newer Cisco Nexus 9000 Series switches with "EX" or "FX" on the end of the product name. Alternatively Nexus 9364C is supported in 1.1(x) and later ACI Multi-Site release.
For more details on hardware requirements and compatibility information, refer to ACI Multi-Site Hardware Requirements Guide .
This document mainly focuses on ACI and MSC side configuration for Multi-Site deployment and the IPN switch configuration details are not fully covered. However, a few important configurations from IPN switch are listed below for reference purpose.
The following are the configuration used in the IPN device connected to the ACI Spines.
vrf context intersite description VRF for Multi-Site lab
feature ospf
router ospf intersite
vrf intersite
//Towards to Spine109 in Site-A |
// Towards to Spine209 in Site-B |
interface Ethernet1/49 speed 100000 mtu 9216 no negotiate auto no shutdown interface Ethernet1/49.4 mtu 9150 encapsulation dot1q 4 vrf member intersite ip address 172.16.1.34/27 ip ospf network point-to-point ip router ospf intersite area 0.0.0.1 no shutdown |
interface Ethernet1/50 speed 100000 mtu 9216 no negotiate auto no shutdown interface Ethernet1/50.4 mtu 9150 encapsulation dot1q 4 vrf member intersite ip address 172.16.2.34/27 ip ospf network point-to-point ip router ospf intersite area 0.0.0.1 no shutdown |
In this example, we are using the default Control Plane MTU size (9000 bytes) on the Spine nodes.
1. Login the site's APIC and configure iBGP AS and Route Reflector for each site's APIC cluster ( APIC GUI--> System --> System Settings --> BGP Route Reflector) , this is the default BGP Route Route Reflector Policy which will be used for the fabric pod profile.
2. Configure the Fabric POD Profile for each Site's APIC cluster, Go to APIC GUI--> Fabric --> Fabric Policies --> Pod Policies --> Policy Groups, click on the default Pod policy group, select the default "BGP Route Reflector Policy" from the dropdown list, shown as blow.
Configure the Spine access policies for Spine uplink to IPN switch with an AEP(Access Entity Profile) and L3 routed domain( APIC GUI--> Fabric --> Access Policies), this part configuration steps will be omitted here, providing with the screenshots for reference.
1) create the switch profile
2) create the AAEP (Attachable Access Entity Profile), Layer 3 Routed domain and VLAN Pool under access policies, shown as below.
3) create the Spine access port policy Group, here associate the Attached Entity Profile "msite".
4) create the spine interface profile, associate the IPN facing spine access port to the interface policy group created in previous step.
Notes: As for now, there is no need to configure L3Out of OSPF under infra tenant from APIC GUI. We will configure this part via MSC and push the configuration to each site directly later on.
Go to APIC GUI--> Infra --> Policies --> Protocol --> Fabric Ext Connection Policies, then create an Intrasite/Intersite Profile, see screenshot below.
Repeat the above steps to complete APIC side configuration for SiteB ACI fabric.
Configure Fabric Infra General settings: BGP peer type (full mesh - EBGP /route reflector - IBGP)
Once it's done, select one of the sites from the left panel. Then you will see site info in the middle, there are three different configuration level by clicking on different area. If you can click on The Site , the Pod or the Spine, It will allow different settings on the config panel (right panel)
In most cases, the attribute values would have already been retrieved automatically from APIC to MSC.
5. Next, let's click on the Pod area and go to the POD level specific policies.
Here we need to specify the Data Plane Unicast TEP, as shown below.
6. Then click on the Spine area and go to Spine specific infra settings, here we can configure followings (as shown in the screenshot below):
For each interface from spine towards to IPN Switch, set IP address and mask,
BGP peer on (yes),
Control Plane TEP (Router Id),
Spine is Reflector (On)
7. Repeat the steps above for other sites and complete the infra configuration in MSC.
8. Click on the "DEPLOY" button at the top, and this will push the infra configuration to APICs in both sites.
Login the site's APIC and verify the Intrasite/Intersite Profile under Tenant infra> Policies > Protocol > Fabric Ext Connection Policies, the Intersite profile will look like following when site is fully configured/managed by MSC.
And also, the L3Out logical node and interface profile configuration is correctly set in vlan 4.
Login to Spine CLI, verify the BGP l2vpn evpn and OSPF is up on each spine, and also verify the node-role for BGP is msite-speaker.
spine109# show ip ospf neighbors vrf overlay-1 OSPF Process ID default VRF overlay-1 Total number of neighbors: 1 Neighbor ID Pri State Up Time Address Interface 172.16.1.34 1 FULL/ - 04:13:07 172.16.1.34 Eth1/32.32 spine109#
spine109# show bgp l2vpn evpn summary vrf overlay-1
BGP summary information for VRF overlay-1, address family L2VPN EVPN
BGP router identifier 172.16.1.3, local AS number 100
BGP table version is 235, L2VPN EVPN config peers 1, capable peers 1
0 network entries and 0 paths using 0 bytes of memory
BGP attribute entries [0/0], BGP AS path entries [0/0]
BGP community entries [0/0], BGP clusterlist entries [0/0]
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
172.16.2.3 4 200 259 259 235 0 0 04:15:39 0
spine109#
spine109# vsh -c 'show bgp internal node-role'
Node role : : MSITE_SPEAKER
spine209# show ip ospf neighbors vrf overlay-1 OSPF Process ID default VRF overlay-1 Total number of neighbors: 1 Neighbor ID Pri State Up Time Address Interface 172.16.1.34 1 FULL/ - 04:20:36 172.16.2.34 Eth1/32.32 spine209# spine209# show bgp l2vpn evpn summary vrf overlay-1 BGP summary information for VRF overlay-1, address family L2VPN EVPN BGP router identifier 172.16.2.3, local AS number 200 BGP table version is 270, L2VPN EVPN config peers 1, capable peers 1 0 network entries and 0 paths using 0 bytes of memory BGP attribute entries [0/0], BGP AS path entries [0/0] BGP community entries [0/0], BGP clusterlist entries [0/0] Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd 172.16.1.3 4 100 264 264 270 0 0 04:20:40 0 spine209# spine209# vsh -c 'show bgp internal node-role' Node role : : MSITE_SPEAKER
Login to Spine CLI to check and verify Overlay-1 interfaces.
ETEP (Multipod Dataplane TEP)
The Dataplane Tunnel Endpoint address used to route traffic between multiple Pods within the single ACI fabric.
DCI-UCAST (Intersite Dataplane unicast ETEP (anycast per site)
This anycast dataplane ETEP address is unique per site, it's assigned to all the spines connected to the IPN/ISN device and used to receive L2/L3 unicast traffic.
DCI-MCAST-HREP (Intersite Dataplane multicast TEP)
This anycast ETEP address is assigned to all the spines connected to the IPN/ISN device and used to receive L2 BUM (Broadcast, Unknown unicast and Multicast) traffic.
MSCP-ETEP (Multi-Site Control-plane ETEP)
This is the control plane ETEP address, which is also known as BGP Router ID on each spine for MP-BGP EVPN.
spine109# show ip int vrf overlay-1 <snip> lo17, Interface status: protocol-up/link-up/admin-up, iod: 83, mode: etep IP address: 172.16.1.4, IP subnet: 172.16.1.4/32 IP broadcast address: 255.255.255.255 IP primary address route-preference: 1, tag: 0 lo18, Interface status: protocol-up/link-up/admin-up, iod: 84, mode: dci-ucast IP address: 172.16.1.1, IP subnet: 172.16.1.1/32 IP broadcast address: 255.255.255.255 IP primary address route-preference: 1, tag: 0 lo19, Interface status: protocol-up/link-up/admin-up, iod: 85, mode: dci-mcast-hrep IP address: 172.16.1.2, IP subnet: 172.16.1.2/32 IP broadcast address: 255.255.255.255 IP primary address route-preference: 1, tag: 0 lo20, Interface status: protocol-up/link-up/admin-up, iod: 87, mode: mscp-etep IP address: 172.16.1.3, IP subnet: 172.16.1.3/32 IP broadcast address: 255.255.255.255 IP primary address route-preference: 1, tag: 0
spine209# show ip int vrf overlay-1 <snip> lo13, Interface status: protocol-up/link-up/admin-up, iod: 83, mode: etep IP address: 172.16.2.4, IP subnet: 172.16.2.4/32 IP broadcast address: 255.255.255.255 IP primary address route-preference: 1, tag: 0 lo14, Interface status: protocol-up/link-up/admin-up, iod: 84, mode: dci-ucast IP address: 172.16.2.1, IP subnet: 172.16.2.1/32 IP broadcast address: 255.255.255.255 IP primary address route-preference: 1, tag: 0 lo15, Interface status: protocol-up/link-up/admin-up, iod: 85, mode: dci-mcast-hrep IP address: 172.16.2.2, IP subnet: 172.16.2.2/32 IP broadcast address: 255.255.255.255 IP primary address route-preference: 1, tag: 0 lo16, Interface status: protocol-up/link-up/admin-up, iod: 87, mode: mscp-etep IP address: 172.16.2.3, IP subnet: 172.16.2.3/32 IP broadcast address: 255.255.255.255 IP primary address route-preference: 1, tag: 0
At the end, Make sure no faults is seen from MSC (multi-site controller)
Very helpful document for Multisite!
Keep them coming :)
Thank you for putting this together, it was really helpful!
Amazing!!
I was looking for more information about the requirements of the Intersite network:
- what are the supported interconnection technologies that used connect the mutli-site: the white paper was showing Dark fiber from 10G to 100GB, ...is it possible to use MPLS with a bandwidth of 500 MB
- Which kind of switched L3 could be used as an IPN switch? is it enough an Switch Layer 3 or it needs an ASR?
Thank you for the post and your help.
This is a great document, but it needs to be updated now for version 4.2, please add remote L3out configuration and Verification Scenario as well.
Hi @Siemmina
Thanks for your message.
The answers to your questions are documented in the white paper, as quoted below.
Q1: what are the supported interconnection technologies that used connect the mutli-site In terms of bandwidth?
"The recommended connection bandwidth between nodes in a Cisco ACI Multi-Site Orchestrator cluster is from 300 Mbps to 1 Gbps. These numbers are based on internal stress testing while adding very large configurations and deleting them at high frequency. In these tests, bursts of traffic of up to 250 Mbps were observed during high-scale configurations, and bursts of up to 500 Mbps were observed during deletion of a configuration consisting of 10,000 EPGs (that is, beyond the supported scale of 3000 EPGs for Cisco ACI Multi-Site deployments in Cisco ACI Release 3.2(1)). "
Q2: - Which kind of switched L3 could be used as an IPN switch? is it enough an Switch Layer 3 or it needs an ASR?
A2: The Inter-Site Network (ISN) is instead a simpler routed infrastructure required to interconnect the different fabrics (only requiring support for increased MTU). So it doesn't need to be an ASR.
Hope it helps,
Cheers,
Linda
Thanks for your comments, @nkhawaja1
This document explains the steps to setup and configure ACI multi-site fabric from the scratch, it also applies to later release of MSO, remote L3out configuration and Verification Scenario can be a separated document.
Cheers,
Linda
Hi Linda,
Great and very helpful document especially the verification portion.
Thanks for help
Sajid Arain
Hi Linda.
Thank you very much for share this document. Really very helpful.
I've a doubt about WAN connection. When I've a cenario with ISN connected a CPE router, the interface must to be associated to vrf and the SP must be vrf end-to-end toward other site right?
There is any problem in configure it out of vrf?
I ask this because I've a customer that haven't MPLS on WAN link.
Best Regards,
Rod.
Helpful Document
