Cisco OTV and FHRP Isolation
18036
Introduction
This document explains what is First Hop Redundancy Protocol (FHRP—HSRP, VRRP, and so on) isolation in Overlay Transport Virtulization (OTV). In order to allow for the existence of the same default gateway in different locations and optimize the outbound traffic flows (server to client direction) OTV filters FHRP messages across the logical overlay. Given that the same VLAN/IP subnet is available in different sites, the free exchange of FHRP messages across the OTV connection would lead to the election of a single default gateway. This would force traffic to follow a suboptimal path to reach the default gateway (in the site where it is deployed) each time it is required to be routed outside the subnet and the server is located in a different site.
Problem
There are two Datacenter with three layers (Core, Distribution and Access). In Core layer its only routing, in Distribution layer vlans and interfaces vlans, and in Access layer are users. Need to extend vlan 200 from my DC1 to DC2 Site. Vlan 200 is extended to DC2 Site and this work fine without FHRP enable. When HSRP is enabled in DC2 Site in Listen mode but many Servers In DC2 Site with VLAN 100 that get information from DC1 Site in vlan 200 don't work, but ping inter-sites and inter-vlans work very well.
Description
Since HSRP is configured for Vlan 200 in both DC1 (between switch A and B) and DC2 (between switch C and D). Because it is a contiguous subnet all hosts in Vlan 200 has their gateway set to A.B.C.D,  which is the same virtual gateway IP address in both sites. Now ideally traffic from DC1 should exit via switch A and traffic from DC2 should exit via switch C since both of these switches where setup with a same HSRP priority . But this is not what happens by default.
On switch A, the active HSRP device for Vlan 200 becomes switch C. This would be the same on switch B and D. This happens since both switch A and C have their HSRP priorities set to same, the router with the higher interface IP address will be elected as the Active HSRP device. In this case switch C. This means that all traffic towards the gateway of A.B.C.D will be forward to DC2.
FHRP Isolation
FHRP isolation is the act of filtering HSRP, VRRP or GLBP traffic from going across the overlay, and thereby forcing local FHRP elections. There are two parts to filter:
1) The election process should be contained within each site to elect a local active devices.
2) The virtual MAC addresses will still be advertised, which would cause constant MAC move moves. i.e., local site, remote site, local site, etc.
Point number 1 is accomplished using a VLAN ACL on the OTV Edge Devices to filter the respective traffic depending on which FHRP protocol used. To prevent the virtual MAC addresses from causing MAC moves and allow for a cleaner design, an OTV route-map must be configured. This route-map must match the virtual MAC of the FHRP protocol used. You will need to make MAC ACL and IP ACL extended. In case of Nexus switches you can use VACLs for this.
The current Cisco N7K OTV implementation requires separation between SVI routing and OTV encapsulation for a given VLAN. In addition, the Join interface can only be defined as a physical interface (or subinterface) or as a logical one (i.e. Layer 3 port channel or Layer 3 port channel subinterface).
Note: Support for loopback interfaces as OTV Join interfaces is planned for a future NX-OS release.
To meet these constraints, two VDCs will be deployed at the Delta N7Ks:
1) an OTV VDC dedicated to perform the OTV functionality
2) a Distr VDC used to provide SVI routing support.
We could either configure the OTV VDC ‘on-a-stick’ with regards to the Distr VDC, or directly connect the OTV VDC to the transport WAN. Its good to use the ‘on-a-stick’ design. One clear advantage to the ‘on-a-stick’ design is that when the NX-OS no longer requires separation between SVI routing and OTV encapsulation for a given VLAN, Delta will easily be able to migrate to using just the Distr VDC for SVI routing and OTV encapsulation. The only migration steps needed will be to move the OTV configuration from the OTV VDC to the Distr VDC and deactivate the OTV VDC. This migration would be transparent to the rest of the data center network.
Note: There is a small cost, the ‘on-a-stick’ design does use at least an extra pair of interfaces on each N7K.
The N7K also requires that the routed SVI not be carried across the vPC peer link, so a separate Layer 3 link will be implemented between the vPC peers. This Layer 3 link can also be used for the vPC peer-keep alives. The current OTV implementation on the Nexus 7000 enforces the separation between SVI routing and OTV encapsulation for a given VLAN. This separation can be achieved with the traditional workaround of having two separate network devices to perform these two functions.
Configuring FHRP Isolation
Follow these steps to configure FHRP isolation.
Step1. Configure a VLAN ACL (VACL) on the OTV VDC.
ip access-list HSRP_IP
   10 permit udp any 224.0.0.2/32 eq 1985
   20 permit udp any 224.0.0.102/32 eq 1985
 mac access-list HSRP_VMAC
   10 permit 0000.0c07.ac00 0000.0000.00ff any
   20 permit 0000.0c9f.f000 0000.0000.0fff any
Step2. Apply a route-map to the OTV control protocol.
mac-list OTV_HSRP_VMAC_deny seq 10 deny 0000.0c07.ac00 ffff.ffff.ff00
 mac-list OTV_HSRP_VMAC_deny seq 11 deny 0000.0c9f.f000 ffff.ffff.f000
 mac-list OTV_HSRP_VMAC_deny seq 20 permit 0000.0000.0000 0000.0000.0000
 route-map OTV_HSRP_filter permit 10
   match mac-list OTV_HSRP_VMAC_deny
Related Information
Putting Overlay Transport Virtualization (OTV) to Work for You
OTV Technology Introduction and Deployment
Cisco OTV issues
rajib.das
Beginner
Hi I have one query related to HSRP isolation. Suppose I have 4 switches two in each DCs :(Core1-DC1, Core-2 DC1, Core-1 DC2, Core-2 DC2 ) and configured HRSP isolation across DCs.
Suppose I have set the HSRP priority as
Core-1-DC1: 110
Core-2-DC1 : 90
Core-1-DC2: 110
Core-2-DC2 : 90
Is it good or need to set different priorities in all 4 switches. What sould be the best practice. Secondely the HSRP group would be same or different in DC1 & DC2 for same vlan extened through otv.
Thanks..RD
Khurram Noor
Beginner
Hi Rajib,
Its a good practice to use different HSRP group number for the same vlan across two DC, if you are putting in FHRP isolation, if not than you must use same group number.
singssf28
Beginner
I am having a query rehregard FHRP localization.Suppose we isolated the HSRP in both sites which having layer 2 connectivity using OTV with HSRP localisation so in case if one site gateway will go down , does it mean that site totally isolated from layer 3 point of view (the host will not be having any active gateway).Please help me to understand this.
williammanurung
Beginner
Hi @Sandeep Singh ,
Nice article.
But still confuse, lets say I have hsrp vlan 100 on DC1, and then i extend vlan 100 to DC 2.
I connect the server on DC2 with access vlan 100, so can I set the gateway on the server is 10.204.89.1 (VIP HSRP Vlan 100)?
Example Configuration:
interface Vlan100
ip address 10.204.89.2/26
ip ospf passive-interface
ip router ospf 1 area 0.0.0.207
hsrp version 2
hsrp 100
preempt
ip 10.204.89.1
thanks
