Configure ACE to Monitor CDS-IS
618
Introduction
This document explains how to configure probes on ACE in order to monitor Service Router, Streamer, and Origin Server. By default, ACE will consider a host to be opertaional if it is able to resolve its IP address, meaning that the host will be perceived as up and running as long as it is replying to ARP request, even if the service is down. This article explains how to configure probes on ACE in order to monitor the following components:
Service Router
Streamer
Origin Server
The goal is to detect a failure of one physical device and take it out of the load-balancing pool, and generate an snmp trap. Assuming that we have proper connectivity, it is also possible to use the ACE to monitor those appliances even without using the ACE to loadbalance them.
SNMP Trigger
Refer to CISCO-ENHANCED-SLB-MIB and following link for details about how to trigger a trap when a host fails: MIB
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA2_3_0/configuration/administration/guide/snmp.html#wp1204030
Configuration for Service Router
TCP Level Probing
One can probe the Service Router on tcp port 80 (HTTP), tcp port 1935 (RTMP), tcp port 554 (rtsp).
Step 1. Configure the probe
probe tcp TCP_80
interval 5 // probe fired ever 4 seconds
receive 2 // no complete HS after 2 seconds = 1 probe failed
faildetect 2 // two consecutive probe failure = host failed
passdetect interval 3 // once failed, need 3 success to consider host back up again
connection term forced // RST after success, no graceful shutdown
Step 2. Assign the probe(s) to serverfarm
serverfarm host CDE-CACHES
  probe TCP_80
  probe TCP_1935
  rserver LB-SR1 80
    inservice
  rserver LB-SR2 80
    inservice
Remark: by default the host fails if *one* probe fails. To fail the host only if *all* probes fail, use "fail-on-all"
Step 3. Verify the probe status and hosts status
switch/C2# sh probe TCP_80
probe       : TCP_80
type        : TCP
state       : ACTIVE
   port      : 80      address     : 0.0.0.0         addr type  : -
   interval  : 4       pass intvl  : 3               pass count : 3
   fail count: 2       recv timeout: 10
                       --------------------- probe results --------------------
   probe association   probed-address  probes     failed     passed     health
   serverfarm  : CDE-CACHES
     real      : LB-SR1[80]
                       10.1.22.4       21         0          21         SUCCESS
     real      : LB-SR2[80]
                       10.1.22.3       21         0          21         SUCCESS
switch/C2#
switch/C2# sh serverfarm CDE-CACHES
serverfarm     : CDE-CACHES, type: HOST
total rservers : 2
                                                ----------connections-----------
       real                  weight state        current    total      failures
   rserver: LB-SR1
       10.1.22.4:80          8      OPERATIONAL  0          3          9
   rserver: LB-SR2
       10.1.22.3:80          8      OPERATIONAL  0          0          6
switch/C2#
DNS
You can probe and check that the Service Router is able to resolve DNS (e.g. one service as shown here, or the hostname of one CDS-IS host)
probe dns DNS_PROBE
  receive 2
  domain ds1.cds.cisco.com
HTTP
For HTTP, you can probe the Service Router and see if we receive the 302 for a particular service. The probe below will be successful if receive any http reponse code comprised between 200 and 302
probe http SR_HTTP
  interval 5
  faildetect 2
  receive 2
  request method get url ds1.cds.cisco.com
  expect status 200 302
Configuration for Streamer
You can configure exactly the same tcp and http probes for the streamers as for Service Router. The valid http response code for a streamer should be only 200 or 206 or 304.
Configuration for Origin Server
The Origin server has same probes as those for Streamer.
Related Information
Release Notes for Cisco Internet Streamer CDS 2.6.3
Content for Community-Ad
FusionCharts will render here
