Configure and Verify Network State Tracking on Nexus 1000v
2598
Introduction
This is a short guide on how to configure and verify that Network State Tracking is working with the Nexus 1000V.
Network State Tracking allows the Nexus 1000V to determine if an upstream network path has failed and if so fail traffic over to a link that is working.
Updated Feb 14 replaced "vemcmd set" with "vemset" commands
Related Information
Configure and Verify LACP Offload on Nexus 1000v
Nexus 1000v Port-Channel Best Practices
Mauricio Martinez
can you add diagrams?
if I had n4k, followed by N5K, could i use this feature to alert the vNIC that a n5k has gone out?
ivan widjaja
Beginner
From configuration guidelines and limitations:
  • Network State Tracking is only supported with HP  Virtual Connect where one physical link from the Flex-10 fabric appears  as four Flex-10 NICs (physical NICs) to the VMkernel.
Can you confirm it will not work with other blade switch?
ivan
Content for Community-Ad
