Getting WinSCP on n9k to work - Settings/Config required
4790
WinSCP configuration required for Nexus 9000
feature scp
feature bash
Configuration required in WinSCP
Note: We can also just use "run bash" without the "sudo su" part, this has been lab tested too and appears to work as expected.
After these configuration changes are made you can click "ok" then proceed to connecting to the device as per usual.
Jason.
Beginner
Huge thanks Jason !
Beginner
Thank you, Just I need
Content for Community-Ad
