Dick Qiu
Prerequisites
  1. VMware Trunk Port Group is supported from ACI version 2.1
  2. VMM integration must be configured properly
  3. ASA device package must be uploaded to APIC
  4. ASAv version must be compatible with ACI and device package version
Configuration
  • Connect your ASAv VM to the VMM created Trunk Port Groupconnect_vm_to_tpg.pngtrunk_port_group.png
  • Apply L4-L7 template
Verification
diqiu-asav# show int ip br
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         unassigned      YES unset  up                    up
GigabitEthernet0/0.2669    10.1.1.1        YES manual up                    up
GigabitEthernet0/0.2670    10.1.2.1        YES manual up                    up
GigabitEthernet0/1         unassigned      YES unset  administratively down down
GigabitEthernet0/2         unassigned      YES unset  administratively down up
GigabitEthernet0/3         unassigned      YES unset  administratively down up
GigabitEthernet0/4         unassigned      YES unset  administratively down up
GigabitEthernet0/5         unassigned      YES unset  administratively down up
GigabitEthernet0/6         unassigned      YES unset  administratively down up
GigabitEthernet0/7         unassigned      YES unset  administratively down up
GigabitEthernet0/8         unassigned      YES unset  administratively down up
Management0/0              10.66.80.54     YES manual up                    up
The sub-interfaces would be automatically created without additional efforts in the parameters section.
Also the VLANs are automatically allocated from the VMM domain.
We can also check if the VLANs are trunked in the port-group
In the below example:
vlan-2670 is allocated to inside shadow EPG (you won't be able to see this in APIC, that's why it's called "shadow")
vlan-2669 is allocated to outside shadow EPG
vlan-2334 is allocated to db EPG (real EPG)
vlan-2667 is allocated to web EPG
vlan-2670 and vlan-2334 belong to same BD, db.
vlan-2669 and vlan-2667 belong to another BD, web.
And the trunk port group is going to allow all these VLANs.
