Mix and Match Memory for UCS servers
2510
Introduction
Cisco's memory kits for UCS servers are separated into categories because of differing degrees of identical pairing required for each server model. Therefore, mix and match of memory from one particular model to another one might not be possible.
For example,  taking DIMMs from a B440 to a B250 must not be done, as extended memory servers like the B250 are particularly sensitive to memory and have different requirements.
Resolution
The recommendation is to comply with the Memory requirements included in the Blade Server Installation and Service Note for each model.
Refer the table below for information regarding different UCS server models and supported RAM.
Server model
Speed of RAM
Maximum RAM
No. of Sockets
UCS B200 M1
PC3-10600
96 GB12
UCS B230 M1
PC3-10600
256 GB32
UCS B230 M2
PC3-10600
512 GB32
UCS B250 M1/M2
PC3-10600
384 GB48
UCS B440 M1/M2
PC3-10600
512 GB32
UCS C200 M1
PC3-10600
96 GB12
UCS C200 M2
PC3-10600
192 GB12
UCS C210 M1/M2
PC3-10600
192 GB12
UCS C250 M1/M2
PC3-10600
384 GB48
UCS C460 M1/M2
PC3-10600
1 TB64
Related Information
DIMM is shown as Equipped Identity Unestablishable
Difference between full width and half width Blade Servers in UCS
Content for Community-Ad
