Multi-Cloud Solution Accelerator Kit v1.7
154
The Multi-Cloud Solution Accelerator Kit v1.7 for Cisco Intelligent Automation for Cloud Starter Edition includes:
  • Overview PDF
  • Deployment Guide PDF
  • Terms of Use (as a subscriber to this community, you have agreed to these terms)
  • Cisco Cloud Portal 9.3.2 service catalog packages
  • Cisco Process Orchestrator 2.3.2 automation packs
The kit is an extension to Cisco Intelligent Automation for Cloud Starter Edition 3.0.2 and offers:
  • Multiple connections to multiple cloud platforms
  • Support for the following virtual compute management platforms
    • VMware Virtual Center
    • VMware vCloud Director
    • OpenStack Nova Compute
    • Amazon EC2
  • Preliminary support for CloudSync across to discover cloud infrastructure (except vCenter, introduced in v2.0)
  • Organization VDCs (Virtual Datacenters) for assigning resources from cloud connections to organizations
Please note that as a very new solution, Multi-Cloud will continue to evolve over time. We welcome comments and suggestions and will do our best to respond and update as appropriate.
With regard to support, the first point of contact should be this community. If you are having issues, moderators of this forum will determine and advise if a TAC case is appropriate, otherwise issues will be addressed here.
We will be starting to build out Multi-Cloud extensions for IAC 3.1 and expect availability late January.
