mwronkow
Here lies the configuration to provide the same pvlan to both UCS N1k VMs while continuing to protect physical servers on an upstream Nexus.  Note the promiscuous vlan is flipped between the N1k uplink (397) to N7k (396).  The gateway resides on vlan 396.  This is confusing to configure & troubleshoot.  It is highly recommended to use a different pVLAN upstream until UCS supports multiple isolated vlans per vNIC.
# N1k SS1(5.1a)
vlan 396
  private-vlan isolated
vlan 397
  private-vlan primary
  private-vlan association 396
port-profile type vethernet isolated396
  vmware port-group
  switchport mode private-vlan host
  switchport private-vlan host-association 397 396
  no shutdown
  state enabled
port-profile type ethernet pvlan-uplink
  vmware port-group
  switchport mode private-vlan trunk promiscuous
  switchport private-vlan trunk allowed vlan 119,219,396-397
  switchport private-vlan mapping trunk 397 396
  switchport private-vlan trunk native vlan 219
  channel-group auto mode on mac-pinning
  no shutdown
  system vlan 119
  state enabled
# UCS
- trunk all regular vlans
# N7k - 6.0(3) w/ EPLD6.0(2)
  Note: 5.0(2) + 5.x EPLD required to carry +1 pvlan pair per trunk (max 16 pairs per trunk)
feature private-vlan
vlan 396
  private-vlan association 397
vlan 397
interface Ethernet2/14
  description Physical Server - Promiscuous
  switchport
  switchport mode private-vlan promiscuous
  switchport private-vlan mapping 396 397
  no shutdown
interface Ethernet7/25
  description to_UCS#1
  switchport
  switchport mode private-vlan trunk secondary
  spanning-tree port type edge trunk
  spanning-tree bpduguard enable
  spanning-tree bpdufilter enable
  switchport private-vlan trunk allowed vlan 119,219,390-391,396-397
  switchport private-vlan association trunk 396 397
  no shutdown
interface Ethernet7/26
  description to_N5k_router
  switchport
  switchport private-vlan mapping trunk 396 397
  no shutdown
# Upstream N5k / router
interface Vlan396
  no shutdown
  ip address 10.10.20.254/24
SV15b# sh mac address-table vlan 397
VLAN      MAC Address       Type    Age       Port                           Mod
397       0050.56a9.0000    static  0                                        5
397       0050.56a9.0013    static  0                                        5
397       0050.56a9.0000    static  0         Veth13                         6   <---VM
397       0050.56a9.0013    static  0         Veth12                         6   <---VM
397       547f.ee2f.3381    dynamic 0         Po4                            6   <---Router
Total MAC Addresses: 5
f340-31-12-ucs-1-B(nxos)# sh mac address-table vlan 397
   VLAN     MAC Address      Type      age     Secure NTFY    Ports
* 397      0050.56a9.0000    dynamic   0          F    F  Veth736
* 397      0050.56a9.0013    dynamic   0          F    F  Veth736
N7K-VDC04(config-if)# sh mac address-table vlan 396
   VLAN     MAC Address      Type      age     Secure NTFY Ports/SWID.SSID.LID
* 396      0050.56a9.0000    dynamic   0          F    F  Eth7/25
* 396      0050.56a9.0013    dynamic   0          F    F  Eth7/25
* 396      547f.ee2f.3381    dynamic   0          F    F  Eth7/26      <---Router
f340-31-19-5548-1# sh mac address-table vlan 396
        age - seconds since last seen,+ - primary entry using vPC Peer-Link
* 396      0050.56a9.0000    dynamic   10         F    F  Po1000      <---PO to UCS
* 396      0050.56a9.0013    dynamic   0          F    F  Po1000
* 396      547f.ee2f.3381    static    0          F    F  Router
hdecreis
Hi !
Thanks for this wrap-up on the scenario (upstream-nexus: with hosts) - (UCS: without physical srvs) - (1KV: hosting vms).
First, I agree, you should use a different vlan as primary, swapping primary and isolated on the middle hop could be extremely confusing for a supporting team.
I have a less-comfortable scenario: Let's imagine you have the following:
- UCS with
    - ESXi hosts with Nexus 1kv
    - some physical (that is, not ESXi hosts but Win and Linux) hosts
- some physical hosts on the upstream N5K.
All sharing some isolated pvlans.
The only idea (still have to lab it) I've found until now is to:
- dedicate one vNIC on all the 1000v ESXi to each pvlan isolated.
- trunk the isolated+primary pvlans as you would towards "normal" switch on the upstream switch towards UCS
- defines a "proper" pvlan configuration on the UCS, upstream switch, and N1Kv (not promisc-pvlan)
That's really ugly, and does not scale AT ALL.
I can't understand why Cisco is not working on a proper version of PVLAN for UCS: the configuration on the 5K is quite easy, what difference does that make ?
Someone at Cisco, any idea when will UCS support PVLANs _PROPERLY_ ? is that even on the roadmap ?
