Salesforce.com API
XML based web services
Base API Structure and Background at
http://www.salesforce.com/us/developer/docs/api/index.htm
Current Version: 1.0.0.14
Release Date: 4/15/2013
Required CPO Version: 2.3.4.182
Required Automation Packs: None
NOTE: all IDs are in the standard salesforce.com format. Ie. "00GS0000001K7GQ"
Function List
Inputs:
Input.WSDL.Username - username of the user to login with
Input.WSDL.Password - password of the user to login with
Returns:
Output.Login.XML - XML output of the webcall.
Output.Server.URL - URL to make web calls against. Note: the login URL to call against is different than this URL. This URL is also saved to an Extended Target Property of your salesforce.com target
Ouput.Session.ID - session ID that you need to make further web calls after logging in. This is saved to an ETP on your salesforce.com target as well.
Output.User.Email - email address of the user you are logging in with
Inputs:
Input.AccountId - Account ID to create case under
Input.ContractId - contract ID to create case under
Input.Description - Description of the case
Input.Origin - where the case comes from
Input.OwnerId - what person or queue will owe the case. This is a GUID type ID that must be pulled from the salesforce instance. Something like 00GS0000001K7GQ
Input.ParentId - ID of the parent case if such a thing exists.
Input.Priority - priority of the case
Input.Reason - reason for opening of the case
Input.RecordTypeId - the id type of the record assigned to this object
Input.Subject - Headline of the case
Input.SuppliedCompany - company opening the case
Input.SuppliedEmail - email of user opening the case
Input.SuppliedName - name of user opening the case
Input.SuppliedPhone - phone number of user opening the case
Input.Type - type of case
Returns:
Output.Result.XML - XML output of the webcall.
Output.Result.ID - id of the case opened
Inputs:
Input.Case.Object.Id - object ID of the case to add the comment to
Input.Comment - actual comment to add to the case
Returns:
Output.Result.ID - id of the comment added
Inputs:
Input.From.Address - Who is the email from
Input.From.Name - name of the sender the email is from
Input.Parent.Id - case ID that this email should be attached to
Input.Subject - subject of the email
Input.Text.Body - body of the email
Input.To.Address - who the email should be sent to
Returns:
Output.Result.ID - id of the newly created email object
Output.JSON - same as XML output but in a JSON format
Inputs:
Input.End.Date - end date to go through
Input.Object.Type - type of object to search for, ie. "Case"
Input.Start.Date - date to begin search at
Returns:
Output.Result.XML - resultant XML of the call
Output.List.Of.IDs - table of the IDs returned from the query
Inputs:
Input.Query.To.Run - direct input of query to run. ie. "Select Id from Case"
Returns:
Output.Result.XML - Resultant XML output of the query
Inputs:
Input.Field.List - comma delimited set of fields to look for
Input.ID - single object ID to search
Input.Object.Type - type of object to look for
Returns:
Output.Result.XML - output of web call in XML format
Inputs:
Input.Email.Body - body of the email
Input.Email.Subject - subject of the email
Input.Reply.To - email address to reply to if that option is selected
Input.Sender.Display.Name - who sent the email
Input.To.Addresses - comma separated list of addresses to email. ie. " someone@domain.com, someone1@domain.com, someone2@domain.com"
Input.To.BCCAddresses - comma separated list of addresses to blind copy
Input.To.CCAddresses - comma separated list of addresses to carbon copy
Returns:
Output.XML - XML output of the webcall.
Inputs:
Input.Field.To.Update - name of the field to update, ie. "Status"
Input.Object.Id - object ID of the object to update
Input.Value.To.Update.To - value that the field needs to be changed to
Returns:
Output.Success - whether webcall succeeded or failed
Inputs:
Input.Email.Body - email body of email
Input.Email.Subject - email subject
Input.From.Address - who the email is from
Input.From.Sender.Name - who the email is from(display name)
Input.Parent.ID - what object should the email attach to
Input.Reply.To - who should get reply to from email
Input.To.Addresses - comma separated emails to send to
Input.To.BCC.Addresses - comma separated emails to BCC to
Input.To.CC.Addresses - comma separated emails to CC to
NOTE: There is nothing different about this call versus calling the Create and Send separately, but since they have very similar inputs, it is just for ease of use
Returns:
No individual output from this call
