TFTP load-balancing on ACE
3946
Introduction
The purpose of this document is to explain how to configure ACE for TFTP load-balancing. Load-balancing TFPT can be tricky as the TFTP server opens a random UDP port to send data from. Because of this we need a catch-all VIP to source NAT the new connection in the opposite direction. For more info please refer to RFC 1350. TFTP uses two flows and we dont have tftp inpect/fix available in ACE. See below steps to understand the issue.
1) Client initiate the session using  UDP flow to port 69 from a random port,  lets say  X.
2) server replies with data, opening a new UDP flow towards the client. Server's  source port is random, while destination  port for this response  is X .
3) Now ACE has no clue about TFTP flows (lack of tftp fix/inspect), hence client will recieve tftp response from Real server directly.Since the response is not from VIP (where client sent the request),Client will drop the response.
Real Server and Server Farm
Real servers are dedicated physical servers that you typically configure in groups called server farms. These servers provide services to clients, such as HTTP or XML content, streaming media (video or audio), TFTP or FTP uploads and downloads, and so on. You identify real servers with names and characterize them with IP addresses, connection limits, and weight values..
Server farms are groups of networked real servers that contain the same content and that typically reside in the same physical location in a data center. Web sites often comprise groups of servers configured in a server farm. Load-balancing software distributes client requests for content or services among the real servers based on the configured policy and traffic classification, server availability and load, and other factors. If one server goes down, another server can take its place and continue to provide the same content to the clients who requested it.
Configuration
Here is a sample config. The colored part is what is specific for TFTP scenario - this is the config that NATs all UDP connections originated from the servers and sets the VIP address as the source. The rest is classical L4 load-balancing on ACE.
// access-list to catch all traffic
access-list ANYONE line 10 extended permit ip any any
probe icmp PING
// define the tftp servers
rserver host tftp-server1
   ip address 10.10.10.101
   inservice
rserver host tftp-server2
   ip address 10.10.10.102
   inservice
// allocate tftp servers to serverfarm
serverfarm host TFTP-SFARM
   probe PING
   rserver tftp-server1
    inservice
   rserver tftp-server2
    inservice
// create class map to match traffic to tftp server VIP
class-map match-any TO-TFTP-VIP
   description class-map for client to TFTP VIP traffic
   match virtual-address 192.168.0.100 udp eq 69
// create class map to match all return traffic from tftp server
class-map match-any FROM-TFTP-REAL
   description class-map from tftp server to client
   match virtual-address 0.0.0.0 0.0.0.0 udp eq any
policy-map type loadbalance first-match TFTP-POLICY
   class class-default
    serverfarm TFTP-SFARM
// create policy map to define action for traffic to the tftp server
policy-map multi-match CLIENT-VLAN-VIPS
   class TO-TFTP-VIP
    loadbalance vip inservice
    loadbalance policy TFTP-POLICY
    loadbalance vip icmp-reply active
// create policy map to define action for return traffic from tftp server
policy-map multi-match SERVER-VLAN-VIPS
   class FROM-TFTP-REAL
    nat dynamic 100 vlan 20
// define the client side and server side vlans
interface vlan 20
   description CLIENT-VLAN
   ip address 192.168.0.1 255.255.255.0
   access-group input ANYONE
   access-group output ANYONE
   nat-pool 100 192.168.0.100 192.168.0.100 netmask 255.255.255.255   service-policy input CLIENT-VLAN-VIPS
   no shutdown
interface vlan 30
   description SERVER-VLAN
   ip address 10.10.10.254 255.255.255.0
   service-policy input SERVER-VLAN-VIPS   no shutdown
The SERVER-VLAN-VIPS service-policy will NAT all UDP connections from this VLAN to the VIP. If this needs to be done only for certain source IPs, a more creative FROM-TFTP-REAL class-map needs to be configured.
Related Information
ACE Loadbalancing-TFTP server
ACE in HA Mode for FTP Traffic Loadbalancing
Server Load-Balancing Guide vA4(2.0)
Community Member
shouldn't "loadbalance policy APP1-POLICY" be "loadbalance policy TFTP-POLICY" ?
Good catch, thanks! The error was occurred while I was changing policy names to something meaningful...
It should be correct now.
Beginner
Could you please elaborate how to configure this when there is a lot of realservers/serverfarms/VIP's and only these mentioned in this example should loadbalance TFTP.
Dennis
I am not sure I understand your questions. The TFTP VIP on the front end id defined with IP address and with UDP port 69, like any ohther VIPs. This works in a usual way as any other VIP.
The problem with TFTP is when the server openes a new UDP connection. Thos connections need to be NATed to VIP address and this document shows how to do it. If the only application that needs to open UDP connection from inside is TFTP than you can leave as is. However, if there are some other UDP connections that need to initated from the server they will be NATed to VIP address. If this is a problem then you need to change the FROM-TFTP-REAL class-maps so it refern only to TFTP server IPs.
I hope this clarifies the idea.
Ivan
Beginner
Hi Ivan,
I append out config to let you review it. We don't seem to be able to get a connection through the ACE. The addition to your config is that we do source-NAT on the incoming connections. Hope you can help.
probe udp TFTP
  port 69
  interval 5
  passdetect interval 5
  receive 5
rserver host RADINLB-SITE1
  ip address 10.102.8.29
  inservice
rserver host RADINLB-SITE2
  ip address 10.102.8.30
  inservice
rserver host RADINLB-SITE3
  ip address 10.102.8.31
  inservice
rserver host RADINLB-SITE4
  ip address 10.102.8.32
  inservice
rserver host RADINLB-SITE5
  ip address 10.102.8.33
  inservice
serverfarm host RADINLB-TFTP
  probe TFTP
  rserver RADINLB-SITE1 69
    inservice
  rserver RADINLB-SITE2 69
    inservice
  rserver RADINLB-SITE3 69
    inservice
  rserver RADINLB-SITE4 69
    inservice
  rserver RADINLB-SITE5 69
    inservice
sticky ip-netmask 255.255.255.255 address source RADINLB-TFTP
  timeout 60
  replicate sticky
class-map match-any CLIENT-TRAFFIC
  description source-NAT client
  4 match destination-address 10.102.0.4 255.255.255.255
  5 match destination-address 10.102.0.5 255.255.255.255
  6 match destination-address 10.102.0.6 255.255.255.255
  7 match destination-address 10.102.0.7 255.255.255.255
  8 match destination-address 10.102.0.8 255.255.255.255
  9 match destination-address 10.102.0.9 255.255.255.255
  10 match destination-address 10.102.0.10 255.255.255.255
  11 match destination-address 10.102.0.11 255.255.255.255
  12 match destination-address 10.102.0.12 255.255.255.255
  13 match destination-address 10.102.0.13 255.255.255.255
  14 match destination-address 10.102.0.14 255.255.255.255
  15 match destination-address 10.102.0.15 255.255.255.255
  16 match destination-address 10.102.0.16 255.255.255.255
  17 match destination-address 10.102.0.17 255.255.255.255
  18 match destination-address 10.102.0.18 255.255.255.255
  19 match destination-address 10.102.0.19 255.255.255.255
  20 match destination-address 10.102.0.20 255.255.255.255
  21 match destination-address 10.102.0.21 255.255.255.255
  2 match virtual-address 0.0.0.0 0.0.0.0 udp any
class-map match-all RADINLB-TFTP
  2 match virtual-address 10.102.0.18 udp eq 69
policy-map type loadbalance first-match RADINLB-TFTP
  class class-default
    sticky-serverfarm RADINLB-TFTP
policy-map multi-match CLIENT-VIPS
  class RADINLB-TFTP
    loadbalance policy RADINLB-TFTP
    appl-parameter http advanced-options CASE_PARAM
policy-map multi-match NAT-CLIENTS
  class CLIENT-TRAFFIC
    nat dynamic 1 vlan 100
policy-map multi-match SERVER-VIPS
    nat dynamic 2 vlan 10
interface vlan 10
  description op_pr_vip_lb
  ip address 10.102.0.1 255.255.255.0
  alias 10.102.0.3 255.255.255.0
  peer ip address 10.102.0.2 255.255.255.0
  access-group input anyone
  nat-pool 2 10.102.0.18 10.102.0.18 netmask 255.255.255.255
  service-policy input remote-mgmt
  service-policy input CLIENT-VIPS
  service-policy input NAT-CLIENTS
  no shutdown
interface vlan 100
  description op_pr_data_lb_srv
  ip address 10.102.8.252 255.255.255.0
  alias 10.102.8.254 255.255.255.0
  peer ip address 10.102.8.253 255.255.255.0
  nat-pool 1 10.102.15.1 10.102.15.1 netmask 255.255.255.0 pat
  service-policy input CLIENT-VIPS-INSIDE
  service-policy input SERVER-VIPS
  no shutdown
Beginner
The only thing I see in the connection table is on the server-vlan:
lb-cdc01-stt/PROD1# sh conn | i UDP
127327     1  in  UDP   100  10.102.8.252:62922    10.102.8.31:69        --
82451      1  out UDP   100  10.102.8.31:69        10.102.8.252:62922    --
175861     1  in  UDP   100  10.102.8.33:51106     10.102.8.252:62921    --
226828     1  out UDP   100  10.102.8.252:62921    10.102.8.33:51106     --
778728     2  in  UDP   100  10.102.8.252:62920    10.102.8.29:69        --
906746     2  out UDP   100  10.102.8.29:69        10.102.8.252:62920    --
1200654    3  in  UDP   100  10.102.8.252:62921    10.102.8.33:69        --
1240634    3  out UDP   100  10.102.8.33:69        10.102.8.252:62921    --
1232464    3  in  UDP   100  10.102.8.30:55491     10.102.8.252:62923    --
1248321    3  out UDP   100  10.102.8.252:62923    10.102.8.30:55491     --
1272611    3  in  UDP   100  10.102.8.29:62303     10.102.8.252:62920    --
1232908    3  out UDP   100  10.102.8.252:62920    10.102.8.29:62303     --
1261618    3  in  UDP   100  10.102.8.31:58809     10.102.8.252:62922    --
1261190    3  out UDP   100  10.102.8.252:62922    10.102.8.31:58809     --
643974     4  in  UDP   100  10.102.8.252:62923    10.102.8.30:69        --
604642     4  out UDP   100  10.102.8.30:69        10.102.8.252:62923    --
lb-cdc01-stt/PROD1# sh service-policy CLIENT-VIPS class-map RADINLB-TFTP det
Status     : ACTIVE
Description: -----------------------------------------
Interface: vlan 10
  service-policy: CLIENT-VIPS
    class: RADINLB-TFTP
     VIP Address:    Protocol:  Port:
      loadbalance:
        L7 loadbalance policy: RADINLB-TFTP
        VIP Route Metric     : 77
        VIP Route Advertise  : DISABLED
        VIP ICMP Reply       : ENABLED-WHEN-ACTIVE
        VIP State: INSERVICE
        VIP DWS state: DWS_DISABLED
        Persistence Rebalance: ENABLED
        curr conns       : 0         , hit count        : 535
        dropped conns    : 0
        conns per second    : 0
        client pkt count : 535       , client byte count: 39295
        server pkt count : 0         , server byte count: 0
        conn-rate-limit      : 0         , drop-count : 0
        bandwidth-rate-limit : 0         , drop-count : 0
        L7 Loadbalance policy : RADINLB-TFTP
          class/match : class-default
            LB action: :
               sticky group: RADINLB-TFTP
                  primary serverfarm: RADINLB-TFTP
                    state:UP
                  backup serverfarm : -
            hit count        : 535
            dropped conns    : 0
            compression      : off
      compression:
        bytes_in  : 0                          bytes_out : 0
        Compression ratio : 0.00%
                Gzip: 0               Deflate: 0
      compression errors:
        User-Agent  : 0               Accept-Encoding    : 0
        Content size: 0               Content type       : 0
        Not HTTP 1.1: 0               HTTP response error: 0
        Others      : 0
        Parameter-map(s):
          CASE_PARAM
lb-cdc01-stt/PROD1#
There is one error in your config. You should add the bolded line:
timeout 60
replicate sticky
Content for Community-Ad
Cisco COVID-19 Survey
