Community Helping Community
peer-link is down,vPC keep-alive is Suspended
269
Beginner
Ask Me Anything (Formerly known as Ask the Expert)
thru
SW1#
interface Ethernet1/1
no switchport
channel-group 10 mode active
no shutdown
interface Ethernet1/2
no switchport
no shutdown
interface Ethernet1/3
switchport mode trunk
channel-group 20 mode active
interface Ethernet1/4
interface port-channel10
no switchport
ip address 1.1.1.1/24
interface port-channel20
spanning-tree port type network
vpc peer-link
vpc domain 100
role priority 4098
peer-keepalive destination 1.1.1.2 source 1.1.1.1
delay restore 150
auto-recovery
SW2#
no switchport
no shutdown
no switchport
no shutdown
no switchport
ip address 1.1.1.2/24
vpc peer-link
vpc domain 100
role priority 4096
peer-keepalive destination 1.1.1.1 source 1.1.1.2
delay restore 150
auto-recovery
SW1# show port-channel summary
Flags: D - Down P - Up in port-channel (members)
I - Individual H - Hot-standby (LACP only)
s - Suspended r - Module-removed
b - BFD Session Wait
S - Switched R - Routed
U - Up (port-channel)
p - Up in delay-lacp mode (member)
M - Not in use. Min-links not met
Group Port- Type Protocol Member Ports
Channel
10 Po10(RU) Eth LACP Eth1/1(P) Eth1/2(P)
20 Po20(SU) Eth LACP Eth1/3(P) Eth1/4(P)
sw2# show port-channel summary
Channel
SW1# show vpc
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 100
Peer status : peer link is down
vPC keep-alive status : Suspended (Destination IP not reachable)
Configuration consistency status : failed
Per-vlan consistency status : success
Configuration inconsistency reason: Consistency Check Not Performed
Type-2 inconsistency reason : Consistency Check Not Performed
vPC role : none established
Number of vPCs configured : 0
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Disabled (due to peer configuration)
Auto-recovery status : Enabled, timer is off.(timeout = 240s)
Delay-restore status : Timer is off.(timeout = 150s)
Delay-restore SVI status : Timer is off.(timeout = 10s)
Operational Layer3 Peer-router : Disabled
vPC Peer-link status
id Port Status Active vlans
1 Po20 up -
sw2# show vpc
Legend:
vPC domain id : 100
1 Po20 up -
Content for Community-Ad
FusionCharts will render here
