10-05-2025 08:00 AM
Under the Guidelines Limitations Section
https://www.cisco.com/c/en/us/td/docs/dcn/nx-os/nexus9000/106x/configuration/interfaces/cisco-nexus-9000-series-nx-os-interfaces-configuration-guide-release-106x/m_configuring_port_channels_93x.html#id_113874
We have this note
On a Cisco Nexus 92300YC switch, the first 24 ports that are part of the same quadrant. All the ports in the same quadrant must have same speed. Having different speed on ports in a quadrant is not supported. Following are the first 24 ports on the Cisco Nexus 92300YC switch that share same quadrant: 1,4,7,10 2,5,8,11 3,6,9,12 13,16,19,22 14,17,20,23 15,18,21,24
Do we interpret this as
a) All the ports from 1 to 24 to have exactly same speed
or
b) The 4 ports mentioned in each line (Quadrant) only need to have same speed
Ex:
1,4,7,10 can have one same speed (say 10G)
and
2,5,8,11 can have another same speed (say 25G)
Solved! Go to Solution.
10-05-2025 10:10 AM
- @t-anil-kumar Yes 2,5,8,11 can have another speed , the restrictions only apply to ports in the same quadrant
M.
10-05-2025 10:10 AM
M.
10-07-2025 10:51 AM
This sounds like the kind of thing that you had in the Nexus 7000 series where assigning ports to VDCs on some modules had to be restricted to ports within a grouping.
