mmcfarland727
Beginner
9K Nexus Switch Configuration HELP!
I need to apply a NAT configuration for an individual internal IP to be NATed to another internal IP, that is connected to a third party firewall that is situated in our DMZ. The TP firewall in the DMZ is expecting traffic from a specific IP within the subnet that is connected to TP firewall. The server that is in the internal LAN is using the IP 10.4.2.220 and it needs to NAT to 10.170.2.53 when sending traffic to the TP firewall. Please see the diagram attached.
I have never used NAT before on the nexus switches so i am a bit unsure if the following config will work. Please can someone verify if the following is correct?
int vlan 170
ip nat outside
int vlan 2
ip nat inside
ip nat inside source static 10.4.2.220 10.170.2.53
Any help would be appreciated, thanks.
1 ACCEPTED SOLUTION
Sergiu.Daniluk
VIP Engager
Hi @mmcfarland727
Yes, the configuration is good. You are basically translating inside local to inside global. It should work.
One thing you need to add according to config guide:
"If the translated IP is part of the outside interface subnet, then use the ip proxy-arp command on the NAT outside interface"
Reference: https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/interfaces/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x_chapter_0110...
Stay safe,
Sergiu
7 REPLIES 7
Sergiu.Daniluk
VIP Engager
Hi @mmcfarland727
Stay safe,
Sergiu
mmcfarland727
Beginner
Hi Sergiu,
Thank you for your reply.
So, when traffic is destined from Server A to TP firewall it will NAT to 10.170.2.53. Any other traffic that server A transmits will not get NATed as long as it doesn't traverse vlan 170 outbound?
Also will no other IP in vlan 2 be NATEd as we have specified only 10.4.2.220 to be? It sounds obvious but i just want to confirm?
Yes and Yes.
Cheers,
Sergiu
mmcfarland727
Beginner
Thank you Sergiu, i really appreciate your input.
I get the following message when attempting to configure NAT on the relevant interface:
ERROR: NAT configuration Failed: aclqos: TCAM region is not configured. Please configure TCAM region and retry the command (err_id 0x410400C5)
It appears I have to allocate a TCAM region for NAT which also requires a reboot.
Once i have scheduled a maintenance window and configured the TCAM region, i will let you know how the NAT config goes.
Thanks again.
Sergiu.Daniluk
VIP Engager
That's true. You receive the error because by default no TCAM entries are allocated for the NAT feature.You'll need to adjust the TCAM (hardware access-list tcam region nat size).
Looking forward for the results of the config
Take care,
Sergiu
mmcfarland727
Beginner
Hi Sergiu,
Apologies for the late response, i have only just been able to reboot the network and get NAT enabled.
Unfortunately the NAT configuration has not worked, it doesn't appear to be NATing the relevant IP.
I have added the IP Proxy-arp command to the outside interface.
Any suggestions would be appreciated?
Mark
mmcfarland727
Beginner
Hi Sergiu,
The NAT configuration did work!!
The third party we are connecting to have confirmed they can see the relevant packets from the correct IP. When connecting to the URL i was getting a 404 error and thought it hadnt worked, but the TP have confirmed thats what is expected.
So thank you for taking the time to reply and help me with this configuration.
Much appreciated.
Mark
Content for Community-Ad
