419
zaf2001
Beginner
Acl on svi issue
ACL applied on svi IN.
Do i need to permit traffic within vlan too?
If i allow above will the issue be resolved?
or do i need to allow anything else too?
3 REPLIES 3
mkilar
The only "pings" that work currently are the ones to locally hosted IPs - those will not be subject to ACL inspection.
Indeed if you want ping to work between the SVI on both switches - the ACL will need to allow for them.
Right now eg. the ping from Switch2 towards "10.10.10.253" is blocked by the ACL applied on Switch 1.
Best regards,
__
Michal
Can you please suggest acl for switch 1 and switch 2 which will solve this issue?
