Archive Configuration on Nexus93180 through vrf management
jbrunstein
I would like to setup the  archive configuration on Nexus93180YC-EX in NX-OS mode as i already done that on catalyst switches, but as i have pure layer 2 config on the switch, the copy to the ftp server should be done through the vrf management interface. The issue as that i can't find how to do that, because it's not possible tp specify the vrf management interface in the command:
archive
 path ftp://user:pass@192.68.15.1/$(SWITCHNAME).$(TIMESTAMP)
 time period 0
 write memory
Any idea on how do that ? if ever possible ...
Did you solve it in the meanwhile?
I've the same problem
ip ssh source-interface
damian-jimenez
ip ssh source-interface is the way
