01-11-2021 06:53 AM
I would like to configure our Nexus switches to send every command to our central syslog server, as all our catalyst switches do. So on IOS we do it like this
archive log config logging enable notify syslog contenttype plaintext hidekeys
It sends all commands to the buffered log and to our central syslog server
Nov 2 10:58:14.422: %PARSER-5-CFGLOG_LOGGEDCMD: User:admjos logged command:interface GigabitEthernet0/0/2.11 Nov 2 10:58:15.105: %PARSER-5-CFGLOG_LOGGEDCMD: User:admjos logged command:description WAN (L2) Nov 2 10:58:16.634: %PARSER-5-CFGLOG_LOGGEDCMD: User:admjos logged command:exit
How can i do the same on NX-OS?
Solved! Go to Solution.
01-11-2021 07:31 AM
See if this helps.
thanks and regards,
01-11-2021 07:31 AM
See if this helps.
thanks and regards,
