Backup vPC
Mustapha Bassim
Dears
I am planning to make backup vPC path for current vPC path , in aonther mean we have vpc 1 between Nexus 1 and Nexus 2 , I planned to make vpc 2 to be redendet for vpc 1 so is that double ? take in mind the switches are 9318.
Bests
Sergiu.Daniluk
It would be useful to make a drawing with the current topology you have and what you plan to make, because is not clear what you mean by "VPC 1" and "VCP 2", and how Nexus1 and Nexus2 are configured in respective to a VPC domain.
Also, here are a couple of questions which could help us in understanding your setup and desired config change:
1. What are your vpc domains and vpc peers from the domains?
2. What is your vpc peer link (peer links if there are two vpc domains)?
3. What is the vpc portchannel between the vpc domains (if you have two vpc domains)?
Take care,
Sergiu
Hello Dear
the diagram is attached which VPC 1 is the main VPC and peer link is build on it , we want to make the green line be anther vpc let say vpc 2 to be backup in case of the main vpc 1 goes down and take in mind there is one layer 3 interface is for keep a live
Bests
