BGP BMP on Nexus 7K
mahdihabashi
Hi everyone
I wanted to configure BGP BMP on Cisco Nexus 7K but it shows a weird Mode Saying ##Invalid mode ## but it has all commands i needed for configuring bgp bmp. i have configured it there but bmp is not working at all. first of all what is that mode showing in picutre ! then how can i configure bmp on nexus 7k? please help me heros thanks !
Nexus 7710
SUP2E
5 Replies 5
This issue solved or not?
MHM
hi there ,
no this issue is not solved yet dear
Can you share config'
MHM
there are no specific command there ... i go to bgp process then type bmp-server 1 and the mode changes to ##invalid-mode##
in that mode i can configure everything about bmp but simply doesn't work at all ...
I check
N9K support it
N3K support it via API
N7K I dont find any doc. that the Nexus HW support this BGP feature
bad news
MHM
