I have a Nexus9000 C9372TX and a Nexus9000 C93108TC-EX (C9372TX ios nxos.7.0.3.I2.2a.bin & C93108TC ios nxos.7.0.3.I4.3.bin)
in port 53 on both a QSFP-40G-SR-BD
Ethernet1/53
transceiver is present
type is QSFP-40G-SR-BD
name is CISCO-AVAGO
part number is AFBR-79EBPZ-CS2
revision is 01
serial number is AVFx
nominal bitrate is 20600 MBit/sec per channel
Link length supported for 50/125um OM3 fiber is 100 m
cisco id is 13
cisco extended id number is 220
Ethernet1/53
name is CISCO-AVAGO
revision is 01
cisco id is 13
on the c9372tx i get no lights in the transceiver
on my C93108TC the transceiver is lit.
c9372tx
Eth1/53 1 eth access down check speed-group config auto(D) --
C93108TC
Eth1/53 1 eth access down Link not connected auto(D) --
tried removing the speed group but i get
C9372TX-10G-01(config-if)# no speed-group 10000
ERROR: Ethernet1/53: Configuration does not match the port capability.
prior too me connecting the bidi the interface had a qsfp to sfp adapter and a dac cable installed. but i have tried to check the port modes and nothing about break outs.
only thing thats pretty different is sho interface
no lights C9372TX
Ethernet1/53 is down (check speed-group config)
admin state is up, Dedicated Interface
Hardware: 10000/40000 Ethernet, address: 0081.c4a2.ecf0 (bia 0081.c4a2.ecf0)
MTU 1500 bytes, BW 40000000 Kbit, DLY 10 usec
and lit up C93108TC
Ethernet1/53 is down (Link not connected)
Hardware: 1000/10000/25000/40000/50000/100000 Ethernet, address: b08b.cf5a.1ab
0 (bia b08b.cf5a.1ab0)
MTU 1500 bytes, BW 100000000 Kbit, DLY 10 usec
way more hardware numbers LOL
any help thanks!
