Blocked VLANs on uplink ports
NguyenT11
Wondering if anyone has seen this problem before:
We have quite a large distributed VMware environment where we have the multiple Virtual Centers located at HQ managing about 200 remote global sites where each site has 2xESX server running the 1000v (Some sites are terrestrial, some satellite links high latency/low bandwidth).  Each server has 2 physical uplinks to 3750 stack, using LACP portchannels.  About 2 times a month we deal with situations where a single VM loses network connectivity, other VMs on that server have no issues.
Checked everything on the 1000v and 3750, the configs all look good, VLANs are trunked properly.  When I check the VEM itself.  I saw something curious, I was seeing that one of the uplink ports of the etherchannel showed that there was some VLANs blocked "F/B: Port is BLOCKED on some of the vlan".  When I displayed the port VLANs, I see VLANs missing.  So based on the symptoms, I made the assumption that the VM that has lost communication is being hashed to the uplink port with the blocked VLANs, thus the reason why it has lost connectivity to the network.
jkrtav01# module vem 6 execute vemcmd show port vlans
                        Native  VLAN   Allowed
  LTL   VSM Port  Mode  VLAN    State  Vlans
   18     Eth6/2   T        1   FWD    1,64,80,500
  22     Eth6/6   T        1   FWD    500  <-------------missing VLAN 1, 64, 80  --- where 500 is a system VLAN
   49      Veth2   A      500   FWD    500
   50      Veth1   A      500   FWD    500
   51     Veth13   A       80   FWD    80
   52      Veth9   A       64   FWD    64
   53      Veth5   A       64   FWD    64
   54      Veth8   A        1   FWD    1
  305        Po4   T        1   FWD    1,64,80,500
Any one of the following procedures fixes this issue:
1)  reload the VSM
2)  switchover the VSM to the secondary (or back to primary)
3)  bounce the uplink port on the corresponding 3750 port.
Based on the fixes, I'm guessing that there is a synchronization issue between the VSM-> VC-> ESX Host.  The fixes initiates a resync of the port-profile and the proper VLANs are configured on the port.
Running Version:   4.2(1)SV1(4a)
Sometimes this issues shows itself where VMs can't talk to each other between ESX hosts, but they can talk to devices throughout the network.  Again I'm guessing that this is because the etherchannel hash pushes some traffic to the "bad" port.
Any insight would be helpful
Tho
Joe LeBlanc
Hi Tho,
CSCuc46955: VEM port-channel member port lost vlan programming after uplink flapping
- The fix is in SV2(1.1)
You can view the DDTS with this link:
https://tools.cisco.com/bugsearch/bug/CSCuc46955
Joe
Joe LeBlanc
Hi Tho,
Joe
