Breakout on N9K-C9372PX-E
Netmart
Could someone please advise on why breakout feature seem not to work:
Software
  BIOS: version 07.69
 NXOS: version 9.3(10)
  BIOS compile time:  04/08/2021
  NXOS image file is: bootflash:///nxos.9.3.10.bin
  NXOS compile time:  7/8/2022 9:00:00 [07/08/2022 14:10:17]
# sh module
Mod Ports             Module-Type                      Model           Status
1    54   48x1/10G SFP+ 6x40G Ethernet Module   N9K-C9372PX-E         active *
Mod  Sw                       Hw    Slot
1    9.3(10)                  1.0    NA
Mod  MAC-Address(es)                         Serial-Num
1    00-c8-8b-cc-22-14 to 00-c8-8b-cc-22-51  SAL2005Y1X7
Mod  Online Diag Status
1    Pass
(config)# int breakout module 1 port 49 map ?
% Incomplete command
(config)# int breakout module 1 port 49 map 10g-4x
% Invalid parameter detected at '^' marker.
Thank you f00z for providing this document.
I am perplexed that Cisco TAC obviously does not understand their own architecture; Cisco TAC recommend to upgrade this NX switch to RN 9.3.10 in order to gain the breakout functionality. I hope some of Cisco Engineers reading this post and charming in to this discussion. Thanks Netmart.
f00z
Level 3
Level 3
Breakout is not supported on ports connected to the NS ASIC (ALE) .. I.E. the 40g ports on 9372, the 6 40g colored ports on 9332PQ etc.. There's a document here that explains the limitations , of which there are A LOT unfortunately:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/ale_ports/b_Limitations_for_ALE_Uplink_Ports_on_Cisco_Nexus_9000_Series_Switches.html
