hi,
I have C3548P, when I "show license usage" why all the Status are "Unused", I know some need to enable the feature, but how can I enable a feature to see the "24P_LIC_PKG" is being used?
Feature Ins Lic Status Expiry Date Comments
Count
24P_LIC_PKG Yes - Unused never -
24P_UPG_PKG No - Unused -
NXOS_OE_PKG No - Unused -
NXOS_ADVANTAGE_GF No - Unused -
NXOS_ADVANTAGE_M4 No - Unused -
NXOS_ADVANTAGE_XF No - Unused -
NXOS_ESSENTIALS_GF No - Unused -
NXOS_ESSENTIALS_M4 No - Unused -
NXOS_ESSENTIALS_XF No - Unused -
NXOS_ADVANTAGE_M8-16 No - Unused -
LAN_BASE_SERVICES_PKG Yes - Unused never -
NXOS_ESSENTIALS_M8-16 No - Unused -
ALGO_BOOST_SERVICES_PKG No - Unused -
LAN1K9_ENT_SERVICES_PKG Yes - Unused never -
LAN_ENTERPRISE_SERVICES_PKG No - Unused -
If I remember correctly... the 24P_LIC is what is used to convert the 3524P into the 3548P. If you buy a 3524P you actually get a 3548P without the port licence. If you look at both models they both come with 48 ports. It's just one isn't licences to run all 48 ports. Are you using ports 25-48? I've never tested to see if you could make this licence show "in use" on this platform :) interesting to test.
Jason.
