04-05-2013 09:12 AM
hey,
i am trying to create a VSM secondary but for some reason it just won't work, i have filled out all the information including the same domain ID but when i boot up the secondary all i see is a different switch name.
when i run show mod, i dont see the secondary in the list of VSM, does anyone have any troubleshooting ideas
thanks
04-05-2013 09:18 AM
Chris,
I would do the following.
Take a back up of the primary VSM just to be safe. If it's on ESXi, copy run start, shut it down and clone it. Shouldn't take more than a few minutes.
For the secondary try creating it on the same ESXi host as the primary VSM. Assign the nics to all the same port-profiles as the primary.
See if that works.
louis
04-09-2013 05:45 AM
Hi Louis,
Sorry for the delay, been out of the office
i have tried to create on the same host but no joy it never finds the primary VSM.
i get this error
SIOCSIFFLAGS permission denied
not sure what that is doing? any ideas?
thanks for your time
04-09-2013 05:55 AM
hi chris,
what is the output of the command "show system redundancy status" ??
the primary vsm should have the output
Redundancy role
administrative: primary
operational: primary
the secondary
Redundancy role
administrative: secondary
operational: secondary
If there is "standalone"
you must enter the command "system redundany role primary" for the primary vsm
and "system redundany role secondary" for the secondary.
04-10-2013 05:56 AM
thanks that command - system redundany role primary did the trick
thanks alot
07-05-2013 08:51 PM
worked for me too, thanks.
12-30-2015 11:37 AM
This also fixed the problem for me. Thanks!
