Change for L2 to L3 svs mode on an existing deployment
jkuhne
We are currently running L2 svs mode in the lab and I would like to change to L3 mode with the specific configuration additons below.
(not worried about a dedicated control vlan at the moment since this is functional testing).
My question is, will there be any impact to moving to L3 svs mode?  I am expecting this change to only impact control traffic between the VSM and VEM.  We currently have mutliple networks/vlans trunked in on the uplink and I don't want to impact the switching behavior there.
Thanks in advance
Jay
// Current vmkernel interface
port-profile type vethernet 10.201.112.x
  vmware port-group
  switchport access vlan 794
  switchport mode access
  no shutdown
  system vlan 794
  max-ports 128
  state enabled
// Proposed addition
  capability l3control
  capability l3-vservice
// Current svs config
svs-domain
  domain id 4014
  control vlan 794
  packet vlan 794
  svs mode L2
// Proposed change
svs-domain
  svs mode L3 interface mgmt0
manir
Yes you are right. Its only for how the VSM and VEM will communicate.
Addition to svs mode, the control vlan and packet vlan config in svs-domain should be removed using the commands "no control vlan" and "no packet vlan".
svs-domain
     no control vlan
     no packet vlan
Before making the svs-domain config change you will need to disconnect the svs connection to vCenter, make the changes and then re-connect it.
A detailed migration guide is availalble in the below link.
Cisco Nexus 1000V Installation and Upgrade Guide, Release 4.2(1)SV2(2.1x) Series  - Upgrading the Cisco Nexus 1000V  [Ci…
Also the capability l3-vservice is not mandatory unless you are using any vsg/vpath services.
Manikanta
Recognize Your Peers
