02-09-2023 04:10 AM
Hi All
Could you please tell me if there is a need to upgrade Cisco 9400 that is on 16.11?
IF yes what should be the version to go?
Solved! Go to Solution.
02-10-2023 06:35 AM
Yes, it is possible to upgrade a Cisco C9400 from version 16.11.1 to version 17.03.06 directly, without upgrading to any intermediate releases. However, it is always a good practice to review the release notes for each version you are skipping to ensure that there are no compatibility issues or other known issues that might affect the stability or functionality of your network.
02-10-2023 05:56 AM
Hi @beconnect,
Yes, it's generally a good idea to upgrade your Cisco 9400 switch to a newer version of the software to take advantage of new features, security updates, and bug fixes.
You could compare the differents features between Firmware verison here: https://cfnng.cisco.com/compare
02-10-2023 06:13 AM
agreed
is it possible to go directly from 16.11.1 to 17.03.06 (ED recommended actually)?
regards and thanks
02-10-2023 06:35 AM
02-10-2023 07:06 AM
02-24-2023 08:46 AM - edited 02-24-2023 08:47 AM
It went smoothly to IOS 17.03. upgraded via web gui
