Cisco iCAM thresholds 9200 vs 9300(first generation)
sp2720401
Beginner
Beginner
First generation 9300s have an RSTP limit of 500 RSTP instances but 3967 VLANs. First Generation 9200s have an RSTP limit of 3967 RSTP instances and also 3967 VLANs.
Are one of these incorrect? Is there a way to change iCAM thresholds and maximums?
When you compare them, there are some major differences between iCAM max limits and also some very distinct differences in capabilities.
As you move into the EX and later generations of 9300 you get the same maximum thresholds for all 9300s.
In reality should we be using 9300 maximums for the 9200? They can run the exact same NXOS binaries.
0 Replies 0
Recognize Your Peers
