Cisco N7K OS Upgrade
ali007
I am upgrading some N7706s and they are not in VPC but have multiple VDCs on them. they have 2 x supervisor modules i.e. N77-SUP2E and they are current on version 7.3(0)DX(1) the plan is to upgrade them to
8.0(1.
However, I am struggling to identify the path and confused whether I will have to upgrade EPLD separately.
could one of you please help with the path and upgrade process?
thanks.
Sergiu.Daniluk
First, before any upgrades, I strongly advise you to read the upgrade guidelines and release notes of the target NXOS version. In your case:
Upgrade guide NXOS: https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus7000/sw/upgrade/guide/cisco_nexus7000_software_upgrade_and_downgrade_guide_8x.html
Upgrade guide FPGA: https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus7000/sw/epld/cisco_nexus7000_epld_rn_8x.html
Release notes:  https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus7000/sw/release/notes/cisco_nexus7000_release_notes_8x.html
If you read the first document (upgrade guide) you have there a table with supported upgrades to your target NXOS: ISSU Paths for Cisco NX-OS Release 8.0(1). You will see that the upgrade is possible from your running version.
If it would have not been there, then you either look on multi-step ISSU, or a cold upgrade (non-ISSU).
About the FPGA, it all depends on the version on your modules. There is a table called Table 7 Supported Modules with the FPGA in Cisco NX-OS Releases 8.0(1), 8.1(1), and 8.2(1)
If the version is the one in the table, you're good. If not, you need to upgrade
Stay safe,
Sergiu
