09-03-2020 02:32 AM
Hi I am haveing a issue with a Nexus 93240 not able to Copy running startup
pnp-csw-01# copy running-config startup-config
[########################################] 100%
Configuration update aborted: request was aborted
option tried
run bash
sudo su -
cd /nxos/dme_logs/
pwd
ls -l
deleted the .old but still not working last part is to reboot but not an option before service slot
when trying to see log this error comes
pnp-csw-01# sh logg | last 20
not enough memory
pnp-csw-01#
Software
BIOS: version 05.39
NXOS: version 9.3(3)
BIOS compile time: 08/30/2019
NXOS image file is: bootflash:///nxos.9.3.3.bin
NXOS compile time: 12/22/2019 2:00:00 [12/22/2019 14:00:37]
thanks at advanced
Solved! Go to Solution.
09-03-2020 08:05 AM
Looks good. You are safe in case of a reload is required.
Cheers,
Sergiu
09-03-2020 03:43 AM
I would suggest to use "show run diff" just to see if there any unsaved config. The output will show differences between running and startup config.
Example:
DC-Team-N9K-1# show run diff *** Startup-config --- Running-config *************** *** 12,23 **** --- 12,25 ---- + feature nxapi feature bash-shell feature scp-server + cfs eth distribute
What ever is with "+" is present in running but not in startup config.
Stay safe,
Sergiu
09-03-2020 05:23 AM
Great thanks this is the output
pnp-csw-01# show runn diff
*** Startup-config
--- Running-config
*** 17,26 ****
--- 16,26 ----
limit-resource m4route-mem minimum 58 maximum 58
limit-resource m6route-mem minimum 8 maximum 8
feature-set fex
feature telnet
+ feature bash-shell
cfs eth distribute
feature interface-vlan
feature netflow
feature lacp
feature vpc
09-03-2020 08:05 AM
Cheers,
Sergiu
09-16-2022 02:26 AM
Hi, we have the same problem. It's not clear to me what was the solution to:
pnp-csw-01# sh logg
not enough memory
