Cisco Nexus N9K-C9372TX Configuration Guide | Configuration Best Practices
CSCO12094806
Beginner
Beginner
Hi Friends,
We are planning to Replace our Core Switch (C3750- 2 Nos, configured with HSRP) with Nexus N9K-C9372TX (2 Nos.).
Existing core switch (C3750) configurations are mentioned below.
01. Network Attached Storage (Net App) Configuration. NAS having two controller, First Controller is connected to First Core Switch & Second Controller is connected to Second Core Switch Respectively (and this is VLAN 12 & each both switch vlan having ip. No HSRP configuration)
02. VMWare EsXi 6.0 (2 Hosts). each host is connected to both switch (this is on Vlan 6) and HSRP is configured for VLAN 6 b/w two core switches.
03. Trunk Link (EtherChannel) b/w Two Core Switches for HA.
04. Trunk Link for EDGE Switches. Edge switch is connected with both Core switches and make 1st Core Switch as Root Bridge and 2nd as BDR.
So to increase network performance now we are planning to replace existing core switch with Nexus N9K-C9372TX, unfortunately we are not familiar with these Data Center switch.
Kindly guide us to complete our core switch change over with Nexus.
Any reference or guidance is very much appreciated.
SAMED
asamedt@gmail.com
+971 56853 6364
Trilok Kataria
Contributor
Contributor
These are some basic config guides for 2 different NX-OS versions available on the same link I shared above.
If you are having issues I would recommend work with TAC to fix the problem.
Cisco Nexus 9000 Series NX-OS Fundamentals Configuration Guide, Release 6.x
Cisco Nexus 9000 Series NX-OS Fundamentals Configuration Guide, Release 7.x
Trilok Kataria
Contributor
Contributor
You can refer to the following for some basic and detailed information around N9K:
Compare all N9K products:
Compare Models - Cisco
Nexus 9300 10GBaseT Switches
Cisco Nexus 9000 Series Switches - Install and Upgrade Guides - Cisco
Cisco Nexus 9000 Series Switches - Configuration Guides - Cisco
IOS to NX-OS Config conversion Tool (if required)
https://nxmt.cloudapps.cisco.com/terms.htm
Trilok
Hi Trilok,
Thanks for the information.
Unfortunately we are very beginner with Nexus family switch ( NX-OS configuration commands). Could you please share NX-OS commands study material.
Today we Power ON the switch and access the console, after the boot process switch went in to  "(none) login:" mode & asking username and password (we don't know default password), so we tried several password out of this username 'admin' accepted without password & switch went in to " (none)# " mode . only little show commands are available with this mode (this is mentioned below.)
(none) login:
User Access Verification
(none) login:
(none) login:Password:
Login incorrect
(none) login: admin
     Fabric discovery in progress, show commands are not fully functional
     Logout and Login after discovery to continue to use show commands.
(none)# ?
bash: !: command not found
(none)#
(none)# sho
shopt
show
show-donner-version.sh
show-platform-internal-all-support
show-switch-summary
show-system-capacity-support
show-system-capacity-support-lc
show-tech-cmds.txt
show-tech-support
show-tech-support-details-coreplugin
show-tech-support-details-ethplugin
show-tech-support-details-fcplugin
show-tech-support-issu-atl
show-tech-support-issu-vdc
show-tech-support-platform
show-tech-support-platform-lc-comm
show-tech-support-platform-sup
show_debug.sh
show_stby_sup_sprom
show_tech_support_epm
show_tech_support_ipfib_multicast
show_tech_support_ipfib_multicast_detail
show_tech_support_l2mcast
--More--
[K
show_tech_support_mfdm_l2
show_tech_support_mfdm_l3
show_tech_support_mfdm_l3_detail
showconsolefont
showfile
showkey
showmount
(none)# show
Kindly share why this is happening & if possible please share study guide for NX-OS commands and configuration.
SAMED
asamedt@gmail.com
+971 56853 6364
Trilok Kataria
Contributor
Contributor
Recognize Your Peers
