cisco part number for 1Gbase-CISCO-AVAGO
gavinhans
Level 2
Level 2
What is cisco SFP part number for  "1Gbase-CISCO-AVAGO". I am unable to find by "1Gbase-CISCO-AVAGO" or "SFBR-5780APZ-CS2" on cisco.com ccw or https://tmgmatrix.cisco.com/.
Ethernet1/1
transceiver is present
type is 1Gbase-CISCO-AVAGO
name is CISCO-AVAGO
part number is SFBR-5780APZ-CS2
revision is G2.3
serial number is CFG392984B3
nominal bitrate is 8500 MBit/sec
Link length supported for 50/125um OM2 fiber is 50 m
Link length supported for 62.5/125um fiber is 21 m
Link length supported for 50/125um OM3 fiber is 150 m
cisco id is --
cisco extended id number is 4
Christopher Hart
Hi Gavin,
This appears to be a 8Gbps Fibre Channel transceiver. The Cisco PID is most likely either DS-SFP-FC8G-SW or DS-SFP-FC8G-LW.
I hope this helps - thank you!
-Christopher
