08-23-2018 08:39 AM
So if I have a pair of 93k as Core in a vPC domain, and then I have 2 pairs of 9k Access switches that I want to connect to the cores, should I configure these in a vPC domain just as the cores? How do I configure the actual trunk links between them?
08-23-2018 11:14 AM
08-23-2018 03:15 PM
08-24-2018 12:32 AM
It is interesting VPC double sided configuration. I have used succesfully lot of times. The connection between the two N9K layers is done with VPC. Check related section in https://www.cisco.com/c/dam/en/us/products/collateral/switches/nexus-7000-series-switches/C07-572830-00_Agg_Dsgn_Config_DG.PDF
Also search google for "VPC double sided" for more information
Of course, VPC Domain must be different for N9K Access and N9K Core. Also, L3 Routing is forbidden, but I suppose it is not your case.
08-24-2018 03:50 AM
Hi thanks.
L3 routing is forbidded on the access?
So the access are 93k not 92.
I can't open the doc or link - 404
08-24-2018 04:18 AM
Trying link again:
The routing is nos supported trough VPC connections, when the peer adjacency ends in the Nexus VPC. But I suppose that in an Access topology you don´t need it.
08-24-2018 04:26 AM
08-24-2018 04:51 AM
Right. You can connect the Cores 95K in VPC Domain 100 and the 93K Access layer in VPC 101, for example. Four (or more) meshed links between both layers assigned to a VPC in each layer.
Over VPC is not supported dynamic routing. So, you have the option that you say, to configure the SVIs in the Core. If you want to configure SVIs in Access-layer you can, but communication with core only is supported with static routing.
Management SVI, if it is the same VLAN in the four chassis is not problema. It is not dynamic routing, is directly L2 connected.
08-24-2018 06:31 AM
Ok so I would just configure management SVI on ALL core and access switches.
Just configure a normal trunk between Access and Core switches,
Different VPC domains on ALL pairs correct?
08-24-2018 04:51 AM - edited 08-24-2018 04:52 AM
Right. You can connect the Cores 95K in VPC Domain 100 and the 93K Access layer in VPC Domain 101, for example. Four (or more) meshed links between both layers assigned to a VPC in each layer.
Management SVI, if it is the same VLAN in the four chassis is not problem. It is not dynamic routing, is directly L2 connected.
08-24-2018 06:29 AM
08-24-2018 06:50 AM
Routing over vPC is supported since release 7.0(3)I5(1)
Added support for Layer 3 over vPC.
For vPC design and best practices you can refer vPC cisco live session :
https://www.ciscolive.com/global/on-demand-library/?search=VPC#/session/14479207929320017eHp
