I need to interconnect connect Cisco nexus 7k and Brocade VDX6740 switches and i have the following questions
1) Which is the easy way of connecting between these switches L2 or L3 connections?
2) If i use L3 connection between them, can i use static routes to point the routes in to that link with in the switch?
3)What are the best SFP+ 10G multi mode modules for cisco nexus 7k switch to support brocade switch?
Thanks for your help
