Data Center network with 4x Cisco Nexus 93108TC-EX
richter5087
I’m working on a data center design using four Cisco Nexus 93108TC-EX switches — two in DC1 and two in DC2. The goal is to keep the network loop-free and make it operate as a single logical environment, even though the switches are physically split between the two sites.
All servers will use NIC teaming (LACP) for redundancy across these switches.
Is this design feasible? I’d appreciate any thoughts on potential design caveats, redundancy considerations, or best practices for this setup.
Thank you in advance.
tinil
Hey  @richter5087
This is not feasible as:
  • NIC teaming will not work as server links go to two different vPC domains all LACP links must terminate on the same vPC pair.
  • Stretching vPC across datacenters is risky - these links must meet the usual requirements (low latency, dedicated), which are difficult to meet across long distances or across a full datacentre separation.
